There was for long time no activity in the 4xx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in 4xx,
so remove it.
This subsystem is quite old. It has been replaced with a driver-model
version (UCLASS_THERMAL). Boards are free to convert to that if required,
but here is a removal patch that could be applied in the meantime.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
CONFIG_CMD_CHIP_CONFIG
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
CONFIG_CFB_CONSOLE
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
This option only complicates the code unnecessarily, just use
CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are
only five arguments to eeprom {read/write} if this is defined.
If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all
six arguments.
them from include/configs.
We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
As ppc4xx currently only supports the deprecated nand_spl infrastructure
and nobody seems to have time / resources to port this over to the newer
SPL infrastructure, lets remove NAND booting completely.
This should not affect the "normal", non NAND-booting ppc4xx platforms
that are currently supported.
Cc: Tirumala Marri <tmarri@apm.com>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Tom Rini <trini@ti.com>
Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
We do not have to define CONFIG_4xx in board config headers
because it is defined in arch/powerpc/cpu/ppc4xx/config.mk.
include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx".
I believe it is a typo because "CONFIG_4x" is not used at all
in other files.
So, I also deleted "CONFIG_4x" in include/configs/JSE.h.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
CONFIG_EHCI_DCACHE was removed by commit b8adb12
"USB: Drop cache flush bloat in EHCI-HCD". Remove the defines from
the boards configs as well.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
cc: Marek Vasut <marex@denx.de>
cc: Stefan Roese <sr@denx.de>
cc: Tom Rini <trini@ti.com>
cc: Wolfgang Denk <wd@denx.de>
cc: Thierry Reding <thierry.reding@avionic-design.de>
cc: Tom Warren <twarren@nvidia.com>
cc: Stephen Warren <swarren@nvidia.com>
cc: Stefano Babic <sbabic@denx.de>
Adapt the following patch from spl to nand_spl:
Author: Stefano Babic <sbabic@denx.de>
Date: Thu Dec 15 10:55:37 2011 +0100
nand_spl_simple: store ecc data on the stack
Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM
which is likely to contain already loaded data.
The patch saves the oob data and the ecc on the stack replacing
the fixed address in RAM.
CC: Ilya Yanok <yanok@emcraft.com>
CC: Scott Wood <scottwood@freescale.com>
CC: Tom Rini <tom.rini@gmail.com>
CC: Simon Schwarz <simonschwarzcor@googlemail.com>
CC: Wolfgang Denk <wd@denx.de>
While nand_spl is on its way out, in favor of spl, there are still
many boards using it, and conversions are gradual. This allows us
to get rid of CONFIG_SYS_NAND_ECCSTEPS and CONFIG_SYS_NAND_ECCTOTAL now,
which would otherwise be likely to linger unreferenced after a conversion.
It also eliminates a temporary error in the hawkboard_nand build, since
the spl version of the patch removed ECCSTEPS/TOTAL from hawkboard.h, but
the spl conversion is pending (and may be merged via a different tree).
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
include/ppc4xx.h
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
Adds required definitions for EHCI support in sequoia configuration file.
But still keeps the OHCI as default driver.
Signed-off-by: Chris Zhang <chris@seamicro.com>
This patch removes the duplicted implementations of the pci_pre_init()
function by introducing a weak default function for it. This weak default
has a different implementation for some PPC variants. It can be
overridden by a board specific version.
This patch removes the Sequoia "bootstrap" command and replaces it
with the now common command "chip_config".
Please note that the patches with the dynamic PCI sync clock
configuration have to be applied, before this one should go in.
This is because Sequoia has 2 different bootstrap EEPROMs, and
the old bootstrap command configured different values depending
on the detected PCI async clock (33 vs. 66MHz). With the PCI sync
clock patches, this is not necessary anymore. The PCI sync clock
will be configured correctly on-the-fly now.
This patch adds another build target for the AMCC Sequoia PPC440EPx
eval board. This RAM-booting version is targeted for boards without
NOR FLASH (NAND booting) which need a possibility to initially
program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000)
configured to setup the SDRAM, this debugger can load this RAM-
booting image to the target address in SDRAM (in this case 0x1000000)
and start it there. Then U-Boot's standard NAND commands can be
used to program the NAND FLASH (e.g. "nand write ...").
Here the commands to load and start this image from the BDI2000:
440EPX>reset halt
440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin
440EPX>go 0x1000000
Please note that this image automatically scans for an already
initialized SDRAM TLB (detected by EPN=0). This TLB will not be
cleared. This TLB doesn't need to be TLB #0, this RAM-booting
version will detect it and preserve it. So booting via BDI2000
will work and booting with a complete different TLB init via
U-Boot works as well.
Don't run the memory POST on the NAND-booting version. It will
overwrite part of the U-Boot image which is already loaded from NAND
to SDRAM. We were just lucky that it booted at all with this SDRAM
test enabled.
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
This is needed since now with HUSH enabled (amcc-common.h) the image
read from NAND exceeds the previous limit.
