path: root/include/configs/sc_sps_1.h
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-24ARM: mxs: Consolidate configuration optionsMarek Vasut
Pull all the duplicate configuration options into configs/mxs.h from the board configuration files. This reduces the files greatly and makes them somewhat more readable. Besides, we do no longer have such a horrible duplication of code. Note that the mx23evk grew in size slightly. This is due to the CONFIG_SYS_CBSIZE now being set to 1024 as it is on the rest of MXS systems. This patch also fixes the OCRAM size for i.MX23. The i.MX23 has only 32kB of OCRAM, while i.MX28 has 128kB of OCRAM. I verified the configuration didn't change for each of the boards, but I didn't boot-test it on the boards I do not have. I configured U-Boot for each board using the "make ... <board>_config" command and then ran "cpp -I include -dM include/config.h" , which dumped all the configuration options. I did this both before and after this patch and finally compared the results for each MXS board. Actually, the results do differ slightly, since the configs/mxs.h file now properly includes the correct iomux-mx23.h or iomux-mx28.h , so while comparing, I had to ignore these new defines. These have no impact on U-Boot configuration though. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lauri Hintsala <lauri.hintsala@bluegiga.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-03-07mxs: Make ehci-mxs multiport capableMarek Vasut
Rework ehci-mxs so it supports both ports on MX28. It was necessary to wrap the per-port configuration into struct ehci_mxs_port and pull out the clock configuration function. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-04configs:Remove unused macro CONFIG_DISCOVER_PHYAshok
Remove unused macro CONFIG_DISCOVER_PHY from configs. Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-28net: fec_mxc: delete CONFIG_FEC_MXC_MULTITroy Kisky
It is more logical to test for CONFIG_FEC_MXC_PHYADDR to determine whether to define the function fecmxc_initialize. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-11-27Replace CONFIG_MMC_BOUNCE_BUFFER with CONFIG_BOUNCE_BUFFER in configsStephen Warren
Commits 6dc71c8 "MMC: MXS: Toggle the generic bounce buffer on the boards" and 49a627f "MMC: Remove the MMC bounce buffer" replaced CONFIG_MMC_BOUNCE_BUFFER with CONFIG_BOUNCE_BUFFER, but missed converting a few boards over to the new option. Fix this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-09-04SCSPS1: Enable cachesMarek Vasut
Enable caches, make it faster! Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2012-09-01MX28: Move "regs-base.h" include after SoC type configurationOtavio Salvador
For i.MX233 addition the base registers need to be change so the SoC definition needs to be known before the header include. The following boards has been changed: * apx4devkit * m28evk * mx28evk * sc_sps_1 Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01sc_sps_1: Adjust board config to use 'mxs' SoC codeOtavio Salvador
Fix build failure due the move of mx28 code to 'mxs' SoC. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01MX28: Add SchulerControl SC_SPS_1 platformMarek Vasut
This i.MX28 platform supports the following: * 2x FEC ethernet * USB on USBH0 * I2C EEPROM * SPI NVRAM * LEDs Signed-off-by: Marek Vasut <marex@denx.de>
