path: root/include/configs/sc520_cdp.h
2009-12-05i386: Fix malloc initializationGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-04Misc sc520 cdp fixupsGraeme Russ
Now that the PCI, SATA et al compile problems have been resolved, the cludge that was applied to avoid them can be removed Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-04i386: Misc PCI fixupsGraeme Russ
Change PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY (Originally done in commit ff4e66e93c1a, regressed by commit 6d7f610b09f8) Cast PCI_ROM_ADDRESS_MASK to u32 Wrap probe_pci_video() call inside #ifdef CONFIG_VIDEO Change call to pci_find_class() to pci_find_devices(). This is based on a patch submitted on 1st March 2007 (Patch that fixes the compilation errors for sc520_cdp board) by mushtaq_k This patch requires that PCI_VIDEO_VENDOR_ID and PCI_VIDEO_DEVICE_ID be specified in the board config file. Dummy values have been added for the SC520 CDP board to enable compilation, but since I do not have one of these, I do know what the values should be Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-03-20Add basic relocation to i386 portGraeme Russ
2009-03-20Rewrite i386 interrupt handlingGraeme Russ
Rewrite interrupt handling functionality for the i386 port. Separated functionality into separate CPU and Architecture components. It appears as if the i386 interrupt handler functionality was intended to allow multiple handlers to be installed for a given interrupt. Unfortunately, this functionality was not fully implemented and also had the problem that irq_free_handler() does not allow the passing of the handler function pointer and therefore could never be used to free specific handlers that had been installed for a given IRQ. There were also various issues with array bounds not being fully tested. I had two objectives in mind for the new implementation: 1) Keep the implementation as similar as possible to existing implementations. To that end, I have used the leon2/3 implementations as the reference 2) Seperate CPU and Architecture specific elements. All specific i386 interrupt functionality is now in cpu/i386/ with the high level API and architecture specific code in lib_i386. Functionality specific to the PC/AT architecture (i.e. cascaded i8259 PICs) has been further split out into an individual file to allow for the implementation of the PIC architecture of the SC520 CPU (supports more IRQs) Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Rename SC520 Configuration OptionsGraeme Russ
Options are now all uniformly CONFIG_SYS_SC520_<option> Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-01-24Removed all references to CONFIG_SYS_RESET_GENERICGraeme Russ
Generic i386 reset - #define made redundant by weak function Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-09-09Update i386 code (sc520_cdp)Graeme Russ
Attempt to bring i386 / sc520 inline with master Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-08-13drivers/block: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-03-26ata: make the ata_piix driver using new SATA frameworkDave Liu
original ata_piix driver is using IDE framework, not real SATA framework. For now, the ata_piix driver is only used by x86 sc520_cdp board. This patch makes the ata_piix driver use the new SATA framework, so - remove the duplicated command stuff - remove the CONFIG_CMD_IDE define in the sc520_cdp.h - add the CONFIG_CMD_SATA define to sc520_cdp.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the ata_piix driverDave Liu
move the cmd_sata.c from common/ to drivers/ata_piix.c, the cmd_sata.c have some part of ata_piix controller drivers. consolidate the driver to have better framework. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-05include/configs: Use new CONFIG_CMD_* in various s* named board config files.Jon Loeliger
2007-05-15Add driver for S-ATA-controller on Intel processors with Southmushtaq khan
Bridge, ICH-5, ICH-6 and ICH-7. Implementation: 1. Code is divided in to two files. All functions, which are controller specific are kept in "drivers/ata_piix.c" file and functions, which are not controller specific, are kept in "common/cmd_sata.c" file. 2. Reading and Writing from the S-ATA drive is done using PIO method. 3. Driver can be configured for 48-bit addressing by defining macro CONFIG_LBA48, if this macro is not defined driver uses the 28-bit addressing. 4. S-ATA read function is hooked to the File system, commands like ext2ls and ext2load file can be used. This has been tested. 5. U-Boot command "SATA_init" is added, which initializes the S-ATA controller and identifies the S-ATA drives connected to it. 6. U-Boot command "sata" is added, which is used to read/write, print partition table and get info about the drives present. This I have implemented in same way as "ide" command is implemented in U-Boot. 7. This driver is for S-ATA in native mode. 8. This driver does not support the Native command queuing and Hot-plugging. Signed-off-by: Mushtaq Khan <mushtaq_k@procsys.com>
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
