path: root/include/configs/sbc8641d.h
2015-10-19sbc8641d: enable and test CONFIG_SYS_GENERIC_BOARDPaul Gortmaker
2015-10-19sbc8641d: increase monitor size from 256k to 384kPaul Gortmaker
Between v2015.07-rc1 and v2015.07-rc2 this board started silent boot failure. A bisect led to commit 6eed3786c68c8a49d ("net: Move the CMD_NET config to defconfigs"). This commit looks harmless in itself, but it did implicitly add a feature to the image which led to this: u-boot$git describe 6eed3786c68c8a49d v2015.07-rc1-412-g6eed3786c68c ^^^ u-boot$ls -l ../41*/u-boot.bin -rwxrwxr-x 1 paul paul 261476 Oct 16 16:47 ../411/u-boot.bin -rwxrwxr-x 1 paul paul 266392 Oct 16 16:43 ../412/u-boot.bin u-boot$bc bc 1.06.95 Copyright 1991-1994, 1997, 1998, 2000, 2004, 2006 Free Software Foundation, Inc. This is free software with ABSOLUTELY NO WARRANTY. For details type `warranty'. 256*1024 262144 i.e. we finally broke through the 256k monitor size. Jump it up to 384k and fix the hard coded value used in the env offset at the same time. We were probably flirting with the 256k size issue without knowing it when testing on different baselines in earlier commits, but since this is all board specific, a rebase or reorder to put this commit 1st is of little value. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-10-19sbc8641d: set proper environment sector size.Paul Gortmaker
When debugging an env fail due to too small a malloc pool, it was noted that the env write was 256k. But the device sector size is 1/2 that, as can be seen from "fli" output: Bank # 1: CFI conformant flash (16 x 16) Size: 16 MB in 131 Sectors Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x1888 Erase timeout: 4096 ms, write timeout: 1 ms Buffer write timeout: 2 ms, buffer size: 64 bytes Sector Start Addresses: FF000000 E RO FF020000 E RO FF040000 E RO FF060000 E RO FF080000 E RO FF0A0000 E RO FF0C0000 E RO FF0E0000 E RO FF100000 E RO FF120000 E RO [...] FFF00000 RO FFF20000 RO FFF40000 RO FFF60000 RO FFF80000 RO FFFA0000 RO FFFC0000 RO FFFE0000 E RO FFFE8000 RO FFFF0000 E RO FFFF8000 RO => The desired env sector is FFF40000->FFF60000, or 0x20000 in length, just after the 256k u-boot image which starts @ FFF00000. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-10-19sbc8641d: increase malloc pool size to a sane defaultPaul Gortmaker
Currently the board fails to save its env, since the env size is much smaller than the sector size, and the malloc fails for the pad buffer, giving the user visible symptom of: Unable to save the rest of sector (253952) Allow for 1M malloc pool, the same as used on the sbc8548 board. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-10-19sbc8641d: enable command line editingPaul Gortmaker
It is just too painful to use interactively without it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-01-24powerpc: mpc86xx: move CONFIG_MPC86xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC86xx in arch/powerpc/cpu/mpc86xx/config.mk because all target boards with mpc86xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-01-14powerpc/86xx: Convert SBC8641 to use common SRIO init codeKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-10-13ppc: Conditionally compile bat_rw.cPeter Tyser
Only a few PPC boards actually use the common BAT manipulation functions, so only compile it for them. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-20powerpc/86xx: Rename PCI1/2 to PCIE1/2 on MPC8641HPCN & SBC8641Kumar Gala
The MPC8641 boards actually only have PCIE not PCI. Rename so we are uniform with regards to names so we can replace this code with templated code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/86xx: Move PCI/PCIe address defines into common immap_86xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Renamed CONFIG_SYS_PCI1/2_ADDR to CONFIG_SYS_PCI1/2ADDR on MPC8641 boards since its really PCIE controllers and not PCI. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-16mpc86xx: delete unused MPC86xx_DDR_SDRAM_CLK_CNTL definePaul Gortmaker
This is an orphaned legacy leftover that is just polluting the config file namespace. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Rework PCI ATMU setup to handle >4G of memoryKumar Gala
The old PCI ATMU setup code would just mimic the PCI regions into the ATMU registers. For simple memory maps in which all memory, MMIO, etc space fit into 4G this works ok. However there are issues with we have >4G of memory as we know can't access all of memory and we need to ensure that PCICSRBAR (PEXCSRBAR on PCIe) isn't overlapping with anything since we can't turn it off. We first setup outbound windows based on what the board code setup in the pci regions for MMIO and IO access. Next we place PCICSRBAR below the MMIO window. After which we try to setup the inbound windows to map as much of memory as possible. On PCIe based controllers we are able to overmap the ATMU setup since RX & TX links are separate but report the proper amount of inbound address space to the region tracking to ensure there is no overlap. On PCI based controllers we use as many inbound windows as available to map as much of the memory as possible. Additionally we changed all the CCSR register access to use proper IO accessor functions. Also had to add CONFIG_SYS_CCSRBAR_PHYS to some 86xx platforms that didn't have it defined. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-0186xx: Cleanup MP supportKumar Gala
* Use CONFIG_MP instead of CONFIG_NUM_CPUS to match 85xx * Introduce determine_mp_bootpg() helper. We'll need this to address a bug introduced in v2009.03 with 86xx MP booting. We have to make sure to reserve the region of memory used for the MP bootpg() so other u-boot code doesn't use it. * Added dummy versions of cpu_reset(), cpu_status() & cpu_release() to allow cmd_mp.c to build and work. In the future we should look at implementing all these functions. This could be common w/85xx if we use spin tables on 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-13sbc8641d: Fix PCI mapping conceptsBecky Bruce
Rename _BASE to _BUS, as it's actually a PCI bus address, separate virtual and physical addresses into _VIRT and _PHYS, and use each appopriately. This makes the code easier to read and understand, and facilitates mapping changes going forward. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-12-0186xx: Fix non-64-bit compilation problems.Jon Loeliger
Introducing 64-bit (36-bit) support for the MPC8641HPCN failed to accomodate the other two 86xx boards. Introduce definitions for CONFIG_SYS_CCSRBAR_PHYS_{LOW,HIGH} CONFIG_SYS_CCSR_DEFAULT_DBAT{U,L} and CONFIG_SYS_CCSR_DEFAULT_IBAT{U,L} with nominal 32-bit values. Signed-off-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-11-10mpc86xx: Change early FLASH mapping to 1M at CONFIG_MONITOR_BASE_EARLYBecky Bruce
We define CONFIG_MONITOR_BASE_EARLY to define the initial location of the bootpage in flash. Use this to create an early mapping definition for the FLASH, and change the early_bats code to use this. This change facilitates the relocation of the flash since the early mappings are no longer tied to the final location of the flash. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-11-04powerpc: change 86xx SMP boot methodBecky Bruce
We put the bootpg for the secondary cpus into memory and use BPTR to get to it. This is a step towards converting to the ePAPR boot methodology. Also, the code is written to deal properly with more than 4GB of RAM. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-10-2486xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted MPC8610HCPD, MPC8641HPCN, and SBC8641D to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-09-10cmd_mac: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM start in commit ad8f8687b78c3e917b173f038926695383c55555 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
