path: root/include/configs/sbc8548.h
2016-07-21powerpc/85xx: Increase fdt addressScott Wood
Loading the fdt at 0xc00000 fails if the uncompressed kernel image is greater than 12 MiB, which is quite common with modern kernels and multiplatform defconfigs. Move fdtaddr to 0x1e00000 which is just under the ramdiskaddr on most targets. Signed-off-by: Scott Wood <oss@buserror.net> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-14sbc8548: enable and test CONFIG_SYS_GENERIC_BOARDPaul Gortmaker
Tested on the following baseline (note "dirty" since I enabled ALT_BOOT in the config in order to use the alternate boot bank.) Everything seems to work fine with no additional changes. The banner warning message is now gone. --- U-Boot 2014.10-rc1-00075-ge49f14af1349-dirty (Aug 14 2014 - 10:26:15) CPU: 8548E, Version: 2.1, (0x80390021) Core: e500, Version: 2.2, (0x80210022) Clock Configuration: CPU0:990 MHz, CCB:396 MHz, DDR:198 MHz (396 MT/s data rate), LBC:99 MHz L1: D-cache 32 KiB enabled I-cache 32 KiB enabled I2C: ready DRAM: Detected UDIMM SDRAM: 128 MiB 256 MiB (DDR2, 64-bit, CL=3, ECC off) Flash: 72 MiB L2: 512 KiB enabled *** Warning - bad CRC, using default environment PCI: Host, 64 bit, 66 MHz, sync, arbiter 00:01.0 - 8086:1026 - Network controller PCI1: Bus 00 - 00 PCIe1: Root Complex, x1 gen1, regs @ 0xe000a000 02:00.0 - 1148:9e00 - Network controller PCIe1: Bus 01 - 02 In: serial Out: serial Err: serial Net: eTSEC0 [PRIME], eTSEC1 Hit any key to stop autoboot: 0 => ver U-Boot 2014.10-rc1-00075-ge49f14af1349-dirty (Aug 14 2014 - 10:26:15) powerpc-linux-gcc (GCC) 4.5.2 GNU ld (GNU Binutils) 2.21 => --- Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-11sbc8548: enable support for hardware SPD errata workaroundPaul Gortmaker
Existing boards by default have an issue where the LBC SDRAM SPD EEPROM and the DDR2 SDRAM SPD EEPROM both land at 0x51. After the hardware modification listed in the README is made, then the DDR2 SPD EEPROM appears at 0x53. So this implements a board specific get_spd() by taking advantage of the existing weak linkage, that 1st tries reading at 0x53 and then if that fails, it falls back to the old 0x51. Since the old dependency issue of "SPD implies no LBC SDRAM" gets removed with the hardware errata fix, remove that restriction in the code, so both LBC SDRAM and SPD can be selected. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: relocate fixed ddr init code to ddr.c filePaul Gortmaker
Nothing to see here, just a relocation of the fixed ddr init sequence to live in the actual ddr.c file itself. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: Make enabling SPD RAM configuration workPaul Gortmaker
Previously, SPD configuration of RAM was non functional on this board. Now that the root cause is known (an i2c address conflict), there is a simple end-user workaround - remove the old slower local bus 128MB module and then SPD detection on the main DDR2 memory module works fine. We make the enablement of the LBC SDRAM support conditional on being not SPD enabled. We can revisit this dependency as the hardware workaround becomes available. Turning off LBC SDRAM support revealed a couple implict dependencies in the tlb/law code that always expected an LBC SDRAM address. This has been tested with the default 256MB module, a 512MB a 1GB and a 2GB, of varying speeds, and the SPD autoconfiguration worked fine in all cases. The default configuration remains to go with the hard coded DDR config, so the default build will continue to work on boards where people don't bother to read the docs. But the advantage of going to the SPD config is that even the small default module gets configured for CL3 instead of CL4. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: Fix LBC SDRAM initialization settingsPaul Gortmaker
These were cloned from the mpc8548cds platform which has a different memory layout (1/2 the size). Set the values by comparing to the register file for the board used during JTAG init sequence: LSDMR1 0x2863B727 /* PCHALL */ LSDMR2 0x0863B727 /* NORMAL */ LSDMR3 0x1863B727 /* MRW */ LSDMR4 0x4063B727 /* RFEN */ This differs from what was there already in that the RFEN is not bundled in all four steps implicitly, but issued once as the final step. The other difference seen when comparing vs. the register file init, is that since the memory is split across /CS3 and /CS4, the dummy writes need to go to 0xf000_0000 _and_ to 0xf400_0000. We also rewrite the final LBC SDRAM inits as macros, as there is no real need for them to be a local variable that is modified on the fly at runtime. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: enable ability to boot from alternate flashPaul Gortmaker
This board has an 8MB soldered on flash, and a 64MB SODIMM flash module. Normally the board boots from the 8MB flash, but the hardware can be configured for booting from the 64MB flash as well by swapping CS0 and CS6. This can be handy for recovery purposes, or for supporting u-boot and VxBoot at the same time. To support this in u-boot, we need to have different BR0/OR0 and BR6/OR6 settings in place for when the board is configured in this way, and a different TEXT_BASE needs to be used due to the larger sector size of the 64MB flash module. We introduce the suffix _8M and _64M for the BR0/BR6 and the OR0/OR6 values so it is clear which is being used to map what specific device. The larger sector size (512k) of the alternate flash needs a larger malloc pool, otherwise you'll get failures when running saveenv, so bump it up accordingly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: relocate 64MB user flash to sane boundaryPaul Gortmaker
The current situation has the 64MB user flash at an awkward alignment; shifted back from 0xfc00_0000 by 8M, to leave an 8MB hole for the soldered on boot flash @ EOM. But to switch to optionally supporting booting off the 64MB flash, the 64MB will then be mapped at the sane address of 0xfc00_0000. This leads to awkward things when programming the 64MB flash prior to transitioning to it -- i.e. even though the chip spans from 0xfb80_0000 to 0xff7f_ffff, you would have to program a u-boot image into the two sectors from 0xfbf0_0000 --> 0xfbff_ffff so that it was in the right place when JP12/SW2.8 were switched to make the 64MB on /CS0. (i.e. the chip is only looking at the bits in mask 0x3ff_ffff) We also have to have three TLB entries responsible for dealing with mapping the 64MB flash due to this 8MB of misalignment. In the end, there is address space from 0xec00_0000 to 0xefff_ffff where we can map it, and then the transition from booting from one config to the other will be a simple 0xec --> 0xfc mapping. Plus we can toss out a TLB entry. Note that TLB0 is kept at 64MB and not shrunk down to the 8MB boot flash; this means we won't have to change it when the alternate config uses the full 64MB for booting, in TLB0. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11Revert "SBC8548: fix address mask to allow 64M flash"Paul Gortmaker
This reverts commit ccf1ad535ae1c0dc2d466235c668adbdfe3a55b7. The commit "SBC8548: fix address mask to allow 64M flash" essentially made this change: * OR6: - * Addr Mask = 64M = OR6[0:16] = 1111 1100 0000 0000 0 + * Addr Mask = 64M = OR6[0:16] = 1111 1000 0000 0000 0 But this makes no sense, as section 13.3.1.2.1 in the MPC8548ERM v2 clearly indicates the masks: 1111_1111_1000_0000_0 8 Mbytes 1111_1100_0000_0000_0 64 Mbytes 1111_1000_0000_0000_0 128 Mbytes So the original value was correct, and the commit was invalid, causing a 128MB mapping for a 64MB flash device. The problem rears its head when trying to configure u-boot to have access to both flash, since the default memory map is: FB80_0000 – FF7F_FFFF 32-bits 64MB FLASH SODIMM FF80_0000 – FFFF_FFFF 8-bits 8MB FLASH By extending the mapping of the 64MB flash to 128MB, it now conflicts with the normal 8MB boot flash, causing issues. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30sbc8548: reclaim wasted sector in boot flashPaul Gortmaker
By nature of being based off the MPC8548CDS board, this board inherited an ENV_SIZE setting of 256k. But since it has a smaller flash device (8MB soldered on), it has a native sector size of 128k, and hence the ENV_SIZE was causing 2 sectors to be used for the environment. By removing the unused sector, we can push TEXT_BASE up closer to the end of address space and reclaim that sector for any other application. This also fixes the mismatch between TEXT_BASE and MONITOR_LEN reported by Kumar earlier. Since this board also supports the ability to boot off the 64MB SODIMM flash, this change is forward looking with that in mind; i.e. the settings for MONITOR_LEN and ENV_SIZE will work when the 512k sectors of the SODIMM flash are used for alternate boot in the future. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: allow enabling PCI via a make config optionPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, and if you had 33MHz PCI, you had to manually change CONFIG_SYS_NS16550_CLK too, which was not real user friendly, This adds the typical PCI and clock speed make targets to the toplevel Makefile in accordance with what is being done with other boards (i.e. using the "-t" to mkconfig). Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: update PCI/PCI-e support codePaul Gortmaker
The PCI/PCI-e support for the sbc8548 was based on an earlier version of what the MPC8548CDS board was using, and in its current state it won't even compile. This re-syncs it to match the latest codebase and makes use of the new shared PCI functions to reduce board duplication. It borrows from the MPC8568MDS, in that it pulls the PCI-e I/O back to 0xe280_0000 (where PCI2 would be on MPC8548CDS), and similarly it coalesces the PCI and PCI-e mem into one single TLB. Both PCI-x and PCI-e have been tested with intel e1000 cards under linux (with an accompanying dts change in place) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
