This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
Tested on the following baseline (note "dirty" since I enabled
ALT_BOOT in the config in order to use the alternate boot bank.)
Everything seems to work fine with no additional changes. The
banner warning message is now gone.
U-Boot 2014.10-rc1-00075-ge49f14af1349-dirty (Aug 14 2014 - 10:26:15)
CPU: 8548E, Version: 2.1, (0x80390021)
Core: e500, Version: 2.2, (0x80210022)
Clock Configuration:
CPU0:990 MHz,
CCB:396 MHz,
DDR:198 MHz (396 MT/s data rate), LBC:99 MHz
L1: D-cache 32 KiB enabled
I-cache 32 KiB enabled
I2C: ready
DRAM: Detected UDIMM
SDRAM: 128 MiB
256 MiB (DDR2, 64-bit, CL=3, ECC off)
Flash: 72 MiB
L2: 512 KiB enabled
*** Warning - bad CRC, using default environment
PCI: Host, 64 bit, 66 MHz, sync, arbiter
00:01.0 - 8086:1026 - Network controller
PCI1: Bus 00 - 00
PCIe1: Root Complex, x1 gen1, regs @ 0xe000a000
02:00.0 - 1148:9e00 - Network controller
PCIe1: Bus 01 - 02
In: serial
Out: serial
Err: serial
Net: eTSEC0 [PRIME], eTSEC1
Hit any key to stop autoboot: 0
=> ver
powerpc-linux-gcc (GCC) 4.5.2
GNU ld (GNU Binutils) 2.21
Reviewed-by: York Sun <yorksun@freescale.com>
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk
because all target boards with mpc85xx cpu define it.
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
Signed-off-by: York Sun <yorksun@freescale.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
- added to soft_i2c driver new multibus/multiadpater support
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
Existing boards by default have an issue where the LBC SDRAM
SPD EEPROM and the DDR2 SDRAM SPD EEPROM both land at 0x51.
After the hardware modification listed in the README is made,
then the DDR2 SPD EEPROM appears at 0x53. So this implements
a board specific get_spd() by taking advantage of the existing
weak linkage, that 1st tries reading at 0x53 and then if that
fails, it falls back to the old 0x51.
Since the old dependency issue of "SPD implies no LBC SDRAM"
gets removed with the hardware errata fix, remove that restriction
in the code, so both LBC SDRAM and SPD can be selected.
Nothing to see here, just a relocation of the fixed ddr init
sequence to live in the actual ddr.c file itself.
Previously, SPD configuration of RAM was non functional on
this board. Now that the root cause is known (an i2c address
conflict), there is a simple end-user workaround - remove the
old slower local bus 128MB module and then SPD detection on the
main DDR2 memory module works fine.
We make the enablement of the LBC SDRAM support conditional on
being not SPD enabled. We can revisit this dependency as the
hardware workaround becomes available.
Turning off LBC SDRAM support revealed a couple implict dependencies
in the tlb/law code that always expected an LBC SDRAM address.
This has been tested with the default 256MB module, a 512MB
a 1GB and a 2GB, of varying speeds, and the SPD autoconfiguration
worked fine in all cases.
The default configuration remains to go with the hard coded
DDR config, so the default build will continue to work on boards
where people don't bother to read the docs. But the advantage
of going to the SPD config is that even the small default module
gets configured for CL3 instead of CL4.
These were cloned from the mpc8548cds platform which has
a different memory layout (1/2 the size). Set the values
by comparing to the register file for the board used during
JTAG init sequence:
LSDMR1 0x2863B727 /* PCHALL */
LSDMR2 0x0863B727 /* NORMAL */
LSDMR3 0x1863B727 /* MRW */
LSDMR4 0x4063B727 /* RFEN */
This differs from what was there already in that the RFEN is
not bundled in all four steps implicitly, but issued once
as the final step.
The other difference seen when comparing vs. the register file init,
is that since the memory is split across /CS3 and /CS4, the dummy
writes need to go to 0xf000_0000 _and_ to 0xf400_0000.
We also rewrite the final LBC SDRAM inits as macros, as there is
no real need for them to be a local variable that is modified
on the fly at runtime.
This board has an 8MB soldered on flash, and a 64MB SODIMM
flash module. Normally the board boots from the 8MB flash,
but the hardware can be configured for booting from the 64MB
flash as well by swapping CS0 and CS6. This can be handy
for recovery purposes, or for supporting u-boot and VxBoot
at the same time.
To support this in u-boot, we need to have different BR0/OR0
and BR6/OR6 settings in place for when the board is configured
in this way, and a different TEXT_BASE needs to be used due
to the larger sector size of the 64MB flash module.
We introduce the suffix _8M and _64M for the BR0/BR6 and the
OR0/OR6 values so it is clear which is being used to map what
specific device.
The larger sector size (512k) of the alternate flash needs
a larger malloc pool, otherwise you'll get failures when
running saveenv, so bump it up accordingly.
The current situation has the 64MB user flash at an awkward
alignment; shifted back from 0xfc00_0000 by 8M, to leave an 8MB hole
for the soldered on boot flash @ EOM. But to switch to optionally
supporting booting off the 64MB flash, the 64MB will then be mapped
at the sane address of 0xfc00_0000.
This leads to awkward things when programming the 64MB flash prior
to transitioning to it -- i.e. even though the chip spans from
0xfb80_0000 to 0xff7f_ffff, you would have to program a u-boot image
into the two sectors from 0xfbf0_0000 --> 0xfbff_ffff so that it was
in the right place when JP12/SW2.8 were switched to make the 64MB on
/CS0. (i.e. the chip is only looking at the bits in mask 0x3ff_ffff)
We also have to have three TLB entries responsible for dealing with
mapping the 64MB flash due to this 8MB of misalignment.
In the end, there is address space from 0xec00_0000 to 0xefff_ffff
where we can map it, and then the transition from booting from one
config to the other will be a simple 0xec --> 0xfc mapping. Plus we
can toss out a TLB entry.
Note that TLB0 is kept at 64MB and not shrunk down to the 8MB boot
flash; this means we won't have to change it when the alternate
config uses the full 64MB for booting, in TLB0.
This reverts commit ccf1ad535ae1c0dc2d466235c668adbdfe3a55b7.
The commit "SBC8548: fix address mask to allow 64M flash"
essentially made this change:
* OR6:
- * Addr Mask = 64M = OR6[0:16] = 1111 1100 0000 0000 0
+ * Addr Mask = 64M = OR6[0:16] = 1111 1000 0000 0000 0
But this makes no sense, as section 13.3.1.2.1 in the
MPC8548ERM v2 clearly indicates the masks:
1111_1111_1000_0000_0 8 Mbytes
1111_1100_0000_0000_0 64 Mbytes
1111_1000_0000_0000_0 128 Mbytes
So the original value was correct, and the commit was invalid,
causing a 128MB mapping for a 64MB flash device. The problem
rears its head when trying to configure u-boot to have access
to both flash, since the default memory map is:
FB80_0000 – FF7F_FFFF 32-bits 64MB FLASH SODIMM
FF80_0000 – FFFF_FFFF 8-bits 8MB FLASH
By extending the mapping of the 64MB flash to 128MB, it now
conflicts with the normal 8MB boot flash, causing issues.
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals.
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW
macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS.
This is necessary for the assembly-language code that relocates CCSR, since
the assembler does not understand 64-bit constants.
CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the
CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it
should not be defined in a board header file. Similarly,
CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so
it should also not be defined in the board header file.
CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that
CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT,
and so CCSR will not be relocated.
Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot
builds (e.g. NAND) are required to relocate CCSR only during the last stage
(i.e. the "real" U-Boot). All other stages should define
CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated.
README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
When planning for more generalization and Makefile cleanup it became
obvious that the introduction of a separate CONFIG_MK_ name space for
config options that were set through scripting in the Makefile was
not a good idea.
Originally the idea was to provide a script-free approach to supply
configuration options - there was no real need for a separate name
space. But when we now convert the existing Makefile entries to make
use of this approach, it would mean that we have to touch a large
number of board config files and add #ifdef / #define sequences to
"convert" from the CONFIG_MK_ to the CONFIG_ name space.
It seems much cleaner to get rid of this somewhat arbitrary _MK
string now for the few boards that actually use it.
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
because it's convenient.
Remove dupliacted setting of PCI/PCIe address and offsets in board
config.h.
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs.
Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
By nature of being based off the MPC8548CDS board, this
board inherited an ENV_SIZE setting of 256k. But since
it has a smaller flash device (8MB soldered on), it has
a native sector size of 128k, and hence the ENV_SIZE was
causing 2 sectors to be used for the environment.
By removing the unused sector, we can push TEXT_BASE up
closer to the end of address space and reclaim that
sector for any other application. This also fixes the
mismatch between TEXT_BASE and MONITOR_LEN reported by
Kumar earlier.
Since this board also supports the ability to boot off
the 64MB SODIMM flash, this change is forward looking
with that in mind; i.e. the settings for MONITOR_LEN
and ENV_SIZE will work when the 512k sectors of the
SODIMM flash are used for alternate boot in the future.
Prior to this commit, to enable PCI, you had to go manually
edit the board config header, and if you had 33MHz PCI, you
had to manually change CONFIG_SYS_NS16550_CLK too, which was
not real user friendly,
This adds the typical PCI and clock speed make targets to the
toplevel Makefile in accordance with what is being done with
other boards (i.e. using the "-t" to mkconfig).
The PCI/PCI-e support for the sbc8548 was based on an earlier
version of what the MPC8548CDS board was using, and in its
current state it won't even compile. This re-syncs it to match
the latest codebase and makes use of the new shared PCI functions
to reduce board duplication.
It borrows from the MPC8568MDS, in that it pulls the PCI-e I/O
back to 0xe280_0000 (where PCI2 would be on MPC8548CDS), and
similarly it coalesces the PCI and PCI-e mem into one single TLB.
Both PCI-x and PCI-e have been tested with intel e1000 cards
under linux (with an accompanying dts change in place)
The size of the LB SDRAM on this board is 128MB, spanning CS3
and CS4. It was previously only being configured for 64MB on
CS3, since that was what the original codebase of the MPC8548CDS
had. In addition to setting up BR4/OR4, this also adds the TLB
entry for the second half of the SDRAM.
The sbc8548 has a 64MB SODIMM flash module off of CS6 that
previously wasn't enumerated by u-boot. There were already
BR6/OR6 settings for it [used by cpu_init_f()] but there
was no TLB entry and it wasn't in the list of flash banks
reported to u-boot.
The location of the 64MB flash is "pulled back" 8MB from
a 64MB boundary, in order to allow address space for the
8MB boot flash that is at the end of 32 bit address space.
This means creating two 4MB TLB entries for the 8MB chunk,
and then expanding the original boot flash entry to 64MB
in order to cover the 8MB boot flash and the remainder
(56MB) of the user flash.
There are a couple defines and PCI bridge quirks related to the PCI
backplane of the MPC8548CDS that have no meaning in the context of
the port to the sbc8548 board, so delete them.
Also, the form factor of the sbc8548 is a standalone board with a
single PCI-X and a single PCI-e slot. That pretty much guarantees
that it will never be a PCI agent itself, so the host/agent and root
complex/end node distinctions have been removed.
Similarly, since there is no physical connector mapping to PCI2, so
all references of PCI2 in the board support files have been removed
as well.
