path: root/include/configs/sansa_fuze_plus.h
2017-10-03usb: gadget: usb_ether: Move the interfaces to KconfigMaxime Ripard
We need to select an interface for the usb_ether gadget, and they haven't been converted to Kconfig yet. Add a choice to make sure we have an option selected, and convert all the users. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Convert USB_ETHER to KconfigMaxime Ripard
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2014-02-06usb: mv_udc: Rename to ci_udcMarek Vasut
The mv_udc is not marvell-specific anymore. The mv_udc is used to drive generic ChipIdea CI13xxx series OTG cores, so rename the driver to ci_udc instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Stefano Babic <sbabic@denx.de>
2013-09-10ARM: mxs: Add SanDisk Sansa Fuze+ boardMarek Vasut
Add STMP3780-based Sansa Fuze+ board. This board is a small PMP device sporting a CPU which was later rebranded to i.MX233 . Currently supported is USB gadget mode and MMC . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
