path: root/include/configs/sandbox.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-25sandbox: Migrate CONFIG_I2C_EEPROMTom Rini
Most users of CONFIG_I2C_EEPROM were migrated to defconfig a while ago, but sandbox was skipped. Leave it off for sandbox_spl where it does not build, but does not need to be either. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-25sandbox: Add instructions about building on 32-bit machinesSimon Glass
Sandbox is built with 64-bit ints by default. This doesn't work properly on 32-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-14sandbox: Don't use IDE and iotrace in SPLSimon Glass
These functions are not supported in SPL, so drop them. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: mmc: Enable building MMC code for sandboxSimon Glass
Enable building the MMC code for sandbox. This increases build coverage for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Enable systemaceSimon Glass
Enable building the systemace code for sandbox. This increases build coverage for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Enable SATASimon Glass
Enable building the SATA code for sandbox. This increases build coverage for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Enable SCSISimon Glass
Enable building the SCSI code for sandbox. This increases build coverage for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Enable IDESimon Glass
Enable building the IDE code for sandbox. This is for build coverage only. It does not currently work. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-18cmd: fdt: Use separate CMD_FDT Kconfig entry instead of OF_LIBFDTMichal Simek
Create CMD_FDT Kconfig entry to have an option to disable fdt command which is not required for small configuration which requires libfdt only. Enable it by default for all targets which enables OF_LIBFDT. Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fixup flea3/sandbox/id8313/siemens-am33xx/smartweb] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-14Merge git://git.denx.de/u-boot-dmTom Rini
2016-03-14Drop CONFIG_CRAMFS_CMDLINESimon Glass
This option doesn't do anything. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-14dm: sandbox: Enable cbfs and cramfsSimon Glass
Enable these two filesystems to provide better build coverage in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: sandbox: Enable all partition typesSimon Glass
It is useful to have sandbox build as much code as possible to avoid having to build every board to detect build errors. Also we may add tests for some more partition types at some point. Enable all partition types in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-21video: Name consoles by their numberSimon Glass
We must use the console name in the 'stdout' variable to select the one we want. At present the name is formed from the driver name with a suffix indicating the rotation value. It seems better to name them sequentially since this can be controlled by driver order. So adjust the code to use 'vidconsole' for the first, 'vidconsole1' for the second, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-20dm: video: test: Test that bitmap display works correctlySimon Glass
Add a test for the 'bmp' command. Test both the uncompressed and compressed versions of the file, since they use different code paths. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-20dm: video: sandbox: Convert sandbox to use driver model for videoSimon Glass
Now that driver model support is available, convert sandbox over to use it. We can remove a few of the special hooks that sandbox currently has. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-20sandbox: Move CONFIG_VIDEO_SANDBOX_SDL to KconfigSimon Glass
Move this option to Kconfig. This is quite simple as only sandbox uses the driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-11-19sandbox: Enable USB keyboardSimon Glass
Enable the USB keyboard on sandbox, now that we have a suitable emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: Enable console recording and silent consoleSimon Glass
Allow console recording so that tests can use it. Also allow the console output to be suppressed, to reduce test output 'noise'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: add a sandbox timer and basic testThomas Chou
Add a sandbox timer which get time from host os and a basic test. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-09dm: test: Add a new test case for dm_test_eth_rotateBin Meng
Add one more ethernet device node in the sandbox test device tree, with name 'sbe5'. This is to support a new test case for testing network device rotation. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-10sandbox: Move CONFIG_SANDBOX_SERIAL to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-21sandbox: Enable some ENV commandsJoe Hershberger
Enable some additional ENV commands in sandbox to aid in build testing and run testing. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-06sandbox: Don't try distro_bootcmd by defaultSjoerd Simons
For the distro_bootcmds to succeed on the sandbox a bit of setup is required (e.g. network configured or host image bound), so running them by default isn't that useful. Add a -b/--boot command to the sandbox binary, which triggers the distro_bootcmds to run after the other command-line commands. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: rtc: sandbox: Enable real-time clock supportSimon Glass
Enable real-time-clock support in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-19sandbox: add config_distro_defaults and config_distro_bootcmdSjoerd Simons
Make the sandbox setup more generic/examplary by including config_distro_defaults.h and config_distro_bootcmd.h. Among other things this makes it easy to test whether images will boot though with the standard distro bootcmds by running e.g: u-boot -c 'host bind 0 myimage.img ; boot' By default there are 2 target host devices to emulate device with multiple storage devices (e.g. internal ("host 0") and external ("host 1") and verify that the prioritization and fallbacks do work correctly. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: exynos: Move CONFIG_SOUND_SANDBOX to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_CMD_SOUND to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_SOUND to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_TPM_TIS_SANDBOX to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_SPI_FLASH_SANDBOX to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_SANDBOX_SPI to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_SYS_I2C_SANDBOX to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher<hs@denx.de>
2015-04-18sandbox: Move CONFIG_SYS_VSNPRINTF to KconfigSimon Glass
2015-04-18sandbox: Move GPIO CONFIGs to KconfigSimon Glass
Move these over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18Kconfig: Move CONFIG_BOOTSTAGE to KconfigSimon Glass
Move CONFIG_BOOT_STAGE and its associated options to Kconfig. Adjust existing users and code. Signed-off-by: Simon Glass <sjg@chromium.org>
