path: root/include/configs/sama5d4_xplained.h
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-21ARM: at91: sama5: update the spi flash mappingWu, Josh
Also move the spi flash configurations to the at91-sama5_common.h. Current at91 zImage size is about 3.3M, the old mapping is not suitable. So update the spi flash map as following: 0x0 ~ 0x004000: at91bootstrap(16k) 0x04000 ~ 0x008000: u-boot env(16k) 0x08000 ~ 0x060000: u-boot(352k) 0x60000 ~ 0x06c000: dtb (48k) 0x6c000 ~ 0x400000: kernel (3M+592k) In AT91Bootstrap, the U-Boot in spi flash also update to 0x8000, refer to following commit in AT91Bootstrap: 3e91e54 Kconfig: fix spi flash address So also update SPL's u-boot load address to 0x8000 in spi flash. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-21ARM: at91: sama5: move the nandflash env config to at91-sama5_common.hWu, Josh
As all sama5 nandflash env configurations are same, so move them to at91-sama5_common.h. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21ARM: at91: sama5: move the sd/mmc env config to at91-sama5_common.hWu, Josh
As almost all sama5 sd/mmc env configurations are same, so move them to at91-sama5_common.h. Also define CONFIG_ENV_VARS_UBOOT_CONFIG to have the varaible: $board_name. Then we can use 'at91-${board_name}.dtb' as the dtb name. TODO: since sama5d3xek has different dtb name, we need to some extra stuff to make it work on sama5d3xek boards. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-04-01ARM: at91: sama5: move the common part of configurations to at91-sama5_common.hWu, Josh
Create a new configuration file: at91-sama5_common.h. Which includes the configurations that reused by all SAMA5 chips. at91-sama5_common.h includes: - hw macros (clock, text_base and etc.) - default commands. - BOOTARGS - U-Boot common configs. NOTE: NOR flash definition should be put before including the common header. For sama5d3-xplained: - add CMD_SETEXPR For sama5d3xek: - add CMD_SETEXPR - change CONFIG_SYS_MALLOC_LEN to (4*1024*1024) Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-03-18ARM: atmel: armv7: move spl lds to armv7 directoryBo Shen
As the u-boot-spl.lds is used only for armv7 SoCs (includes sama5d3 and sama5d4), so move it to armv7 directory. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-03-18ARM: atmel: sama5d4 boards: fix spl lds locationBo Shen
As the u-boot-spl.lds is moved to <arch/arm/mach-at91> directory. So, correct the path for sama5d4 related boards. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-07ARM: atmel: sama5d4_xplained: enable spl supportBo Shen
2015-01-19ARM: atmel: sama5d4_xplained: enable usb ethernet gadgetBo Shen
2014-11-17ARM: atmel: add sama5d4 xplained ultra board supportBo Shen
The code for this board supports following features: - Boot media support: NAND flash/SD card/SPI flash - Support LCD display (optional, disabled by default) - Support ethernet - Support USB mass storage Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
