Get rid of too many ifdeffery in usb ohci driver
Add following two configuration for USB clock selecting
- CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock
- CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Add RNDIS gadget support to test atmel usba udc driver
Drop unused CONFIG_NET_MULTI
Signed-off-by: Bo Shen <voice.shen@gmail.com>
fix typo error for CONFIG_ENV_IS_NOWHERE from CONIG_ENV_IS_NOWHERE
The CONFIG_MAX_NAND_CHIPS never used, remove it
No where define LCD_TEST_PATTERN, so no need undefine
Define the galois index table offset in chip head file. So user do not need
to set by himself. Driver will set it correctly according to sector_size.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Scott Wood <scottwood@freescale.com>
[rebased on master]
add gmac support for sama5d3xek board, the gmac embedded in:
- sama5d33, sama5d34, sama5d35
[trini: Fixup common/cmd_io.c]
Add sama5d3xek support with following feature
- boot from NAND flash, PMECC support, 4bit ECC @ 512 bytes sector
- boot from SPI flash support
- boot from SD card support
- LCD support
- EMAC support
- USB OHCI support
