path: root/include/configs/sama5d3xek.h
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-14board: sama5d3xek: Clean up codeWenyou Yang
Due to the introduction of the pinctrl and clk driver, and using device tree files, remove the unneeded hardcoded pin configuration and clock enabling code from the board file. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Remove CONFIG_PHY_MICREL as per previous patch: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-14board: sama5d3xek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model, so do SPL. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Add back CONFIG_PHY_MICREL to prevent a build error: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-21ARM: at91: sama5: update the spi flash mappingWu, Josh
Also move the spi flash configurations to the at91-sama5_common.h. Current at91 zImage size is about 3.3M, the old mapping is not suitable. So update the spi flash map as following: 0x0 ~ 0x004000: at91bootstrap(16k) 0x04000 ~ 0x008000: u-boot env(16k) 0x08000 ~ 0x060000: u-boot(352k) 0x60000 ~ 0x06c000: dtb (48k) 0x6c000 ~ 0x400000: kernel (3M+592k) In AT91Bootstrap, the U-Boot in spi flash also update to 0x8000, refer to following commit in AT91Bootstrap: 3e91e54 Kconfig: fix spi flash address So also update SPL's u-boot load address to 0x8000 in spi flash. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-21ARM: at91: sama5: move the nandflash env config to at91-sama5_common.hWu, Josh
As all sama5 nandflash env configurations are same, so move them to at91-sama5_common.h. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21ARM: at91: sama5d3xek: use a $dtb_name to load dtbWu, Josh
Since sama5d3xek boards has different type of dtb blobs, so we need to detect the cpu type in runtime. So we add a new variable $dtb_name. if $dtb_name is not defined, we just use at91-${board_name}.dtb as the $dtb_name. Otherwise, we will just load the dtb with $dtb_name. For sama5d3xek, we will detect cpu type and make up $dtb_name in runtime. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21ARM: at91: sama5: move the sd/mmc env config to at91-sama5_common.hWu, Josh
As almost all sama5 sd/mmc env configurations are same, so move them to at91-sama5_common.h. Also define CONFIG_ENV_VARS_UBOOT_CONFIG to have the varaible: $board_name. Then we can use 'at91-${board_name}.dtb' as the dtb name. TODO: since sama5d3xek has different dtb name, we need to some extra stuff to make it work on sama5d3xek boards. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-04-01ARM: at91: sama5: move the common part of configurations to at91-sama5_common.hWu, Josh
Create a new configuration file: at91-sama5_common.h. Which includes the configurations that reused by all SAMA5 chips. at91-sama5_common.h includes: - hw macros (clock, text_base and etc.) - default commands. - BOOTARGS - U-Boot common configs. NOTE: NOR flash definition should be put before including the common header. For sama5d3-xplained: - add CMD_SETEXPR For sama5d3xek: - add CMD_SETEXPR - change CONFIG_SYS_MALLOC_LEN to (4*1024*1024) Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-03-18ARM: atmel: armv7: move spl lds to armv7 directoryBo Shen
As the u-boot-spl.lds is used only for armv7 SoCs (includes sama5d3 and sama5d4), so move it to armv7 directory. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
2015-02-07ARM: at91: sama5d3xek: save enviroment as a FAT file in MMC cardWu, Josh
This patch will save U-Boot environment as a file: uboot.env, in FAT partition instead of in raw sector of MMC card. This make us easier to manage the environment file. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-09-24spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*Nikita Kiryanov
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in SPL. These #defines do not allow the user to select SPI mode for the SPI flash (there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in spi_spl_load.c), and duplicate information already provided by CONFIG_SF_DEFAULT_* #defines. Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead. Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Hannes Petermaier <hannes.petermaier@br-automation.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-09-19ARM: atmel: sama5d3xek: enable NOR flash supportBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-27at91: remove redundant AT91FAMILY definition in board config fileWu, Josh
Now the AT91FAMILY is already defined in the at91 SoC header. The at91 board config file will include the SoC header file. So we can remove the redundant AT91FAMILY definition in at91 board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase patch] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27sama5d3xek: enable PMECC header generationAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Tested-by: Bo Shen <voice.shen@atmel.com>
2014-05-27ARM: atmel: sama5d3xek: convert to generic boardBo Shen
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on boot: "Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed." Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-09arm: atmel: sama5d3: add nand spl boot supportBo Shen
Add NAND SPL boot support with hardware PMECC. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-09arm: atmel: sama5d3: add spi spl boot supportBo Shen
Add SPI SPL boot support for sama5d3xek board. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-01arm: atmel: sama5d3: spl boot from fat fs SD cardBo Shen
Enable Atmel sama5d3xek boart spl boot support, which can load u-boot from SD card with FAT file system. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
