path: root/include/configs/sama5d3_xplained.h
2019-01-21ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to KconfigDerald D. Woods
This commit converts the following items to Kconfig: CONFIG_ATMEL_NAND_HWECC CONFIG_ATMEL_NAND_HW_PMECC CONFIG_PMECC_CAP CONFIG_PMECC_SECTOR_SIZE CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER [PMECC References] https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap [Mailing List Thread] https://lists.denx.de/pipermail/u-boot/2018-December/350666.html Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment") [trini: Make the migration be size neutral and possibly not fix the above in all cases] Reported-by: Daniel Evans <photonthunder@gmail.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-14ARM: at91: Remove hardware.h included in configsWenyou Yang
As said in READRE.kconfig, include/configs/*.h will be removed after all options are switched to Kconfig. As the first step, remove the follow line from include/configs/*.h. #include <asm/hardware.h> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-14board: sama5d3_xplained: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model, so do SPL. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Fix build error with sama5d3_xplained_mmc: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2015-08-21ARM: at91: sama5: move the nandflash env config to at91-sama5_common.hWu, Josh
As all sama5 nandflash env configurations are same, so move them to at91-sama5_common.h. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21ARM: at91: sama5: move the sd/mmc env config to at91-sama5_common.hWu, Josh
As almost all sama5 sd/mmc env configurations are same, so move them to at91-sama5_common.h. Also define CONFIG_ENV_VARS_UBOOT_CONFIG to have the varaible: $board_name. Then we can use 'at91-${board_name}.dtb' as the dtb name. TODO: since sama5d3xek has different dtb name, we need to some extra stuff to make it work on sama5d3xek boards. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-04-01ARM: at91: sama5: move the common part of configurations to at91-sama5_common.hWu, Josh
Create a new configuration file: at91-sama5_common.h. Which includes the configurations that reused by all SAMA5 chips. at91-sama5_common.h includes: - hw macros (clock, text_base and etc.) - default commands. - BOOTARGS - U-Boot common configs. NOTE: NOR flash definition should be put before including the common header. For sama5d3-xplained: - add CMD_SETEXPR For sama5d3xek: - add CMD_SETEXPR - change CONFIG_SYS_MALLOC_LEN to (4*1024*1024) Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-03-18ARM: atmel: armv7: move spl lds to armv7 directoryBo Shen
As the u-boot-spl.lds is used only for armv7 SoCs (includes sama5d3 and sama5d4), so move it to armv7 directory. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
2015-02-07ARM: at91: sama5d3_xplained: save environment in a FAT file in MMC cardWu, Josh
This patch will save U-Boot environment as a file: uboot.env, in FAT partition instead of saving it in raw sector of MMC card. This make us easier to manage the environment file. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2015-01-19ARM: at91: sama5d3_xplained: spl: enable PMECC header generationWu, Josh
As sama5d3 xplained support the PMECC. So add the PMECC header for spl binary. That make ROM loader can use PMECC to avoid error flips in spl code in nandflash. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-27at91: remove redundant AT91FAMILY definition in board config fileWu, Josh
Now the AT91FAMILY is already defined in the at91 SoC header. The at91 board config file will include the SoC header file. So we can remove the redundant AT91FAMILY definition in at91 board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase patch] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: atmel: sama5d3_xplained: convert to generic boardBo Shen
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on boot: "Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed." Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: atmel: enable SPL on sama5d3_xplained boardBo Shen
It supports boot from NAND and SD/MMC card. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-12config: remove platform CONFIG_SYS_HZ definition part 4Masahiro Yamada
Some new boards define CONFIG_SYS_HZ again! Remove. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Bo Shen <voice.shen@atmel.com>
