path: root/include/configs/salvator-x.h
2017-05-22ARM: rmobile: salvator-x: Enable SCIF2 clockMarek Vasut
There are two UARTs on the board, so enable the clock for the second one as well. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Add USB supportMarek Vasut
Add support for the EHCI USB. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Add DVFS and PMIC supportMarek Vasut
Add support for rebooting the board using the ROHM BD9571MWV I2C PMIC, but keep the CPU reboot option as a fallback. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Add RAVB ethernet supportMarek Vasut
Add support for the AVB ethernet on the Salvator-X board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Add SD supportMarek Vasut
Add support for the SD card slots on the Salvator-X board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Adjust UART clockMarek Vasut
The UART uses internal SCIF clock except on R8A7795 H3 WS1.0 . Use the internal clock and ignore the early version of the chip. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support salvator-x boardNobuhiro Iwamatsu
Salvator-x is an entry level development board based on R-Car H3 SoC (R8A7795). This commit supports SCIF only. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
