path: root/include/configs/s5p_goni.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-28arm: goni: remove config.mk fileMinkyu Kang
Since config.mk is deprecated, remove this file, and move CONFIG_SYS_TEXT_BASE define to config file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2012-11-14power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWERŁukasz Majewski
Rename all CONFIG_PMIC* defines to CONFIG_POWER* Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-08ARM: SAMSUNG: support sdhci controllerJaehoon Chung
To support sdhci controller, remove the CONFIG_S5P_MMC.. Instead, use the CONFIG_S5P_SDHCI/CONFIG_SDHCI. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Lei Wen<leiwen@marvell.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2011-12-11usb:gadget:s5p Enable the USB Gadget framework at GONILukasz Majewski
This commit enables support for USB Gadgets on the GONI reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-11-03dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI targetŁukasz Majewski
Define the D-cache line size for S5PC110 GONI reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Anton Staaf <robotboy@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-10-27misc:pmic:samsung Enable PMIC driver at GONI targetŁukasz Majewski
Enable support for new PMIC driver at GONI reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2011-09-04i2c:gpio:s5p: Enable I2C GPIO on the GONI targetŁukasz Majewski
This patch enables the software I2C for GONI reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-03-27S5P: goni: Enable the pwm driverMinkyu Kang
2010-11-30S5P: goni: fix for relocationMinkyu Kang
Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-26ARMV7: S5P: rename from CONFIG_S5PC1XX to CONFIG_S5PMinkyu Kang
Use the same configuration around S5P SoCs. (s5pc100, s5pc110, s5pc210 and so on) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-04Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-08-03s5p_goni: enable mmc0Minkyu Kang
Adds the board_mmc_init function and enable the mmc command Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-14s5pc1xx: Add support for Samsung Goni boardMinkyu Kang
This patch adds support for the Samsung Goni board (S5PC110 SoC) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-06-03s5pc1xx: Add support for Samsung Goni boardMinkyu Kang
