path: root/include/configs/s32v234evb.h
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-15i2c: Drop use of CONFIG_I2C_HARDSimon Glass
This option is pretty old. It predates CONFIG_SYS_I2C which is itself deprecated in favour of driver model. Disable it for all boards. Also drop I2C options which depend on this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-04mmc: move CONFIG_SYS_FSL_ERRATUM_ESDHC* to KconfigYork Sun
Add option SYS_FSL_ERRATUM_ESDHC111, SYS_FSL_ERRATUM_ESDHC13, SYS_FSL_ERRATUM_ESDHC135, SYS_FSL_ERRATUM_ESDHC_A001 to mmc Kconfig. Move existing macros to related Kconfig. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate bk4r1] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03cmd: move CMD_PXE to KconfigYann E. MORIN
Currently, CMD_PXE is forcibly enabled in config_distro_defaults.h, so that general purpose distributions can rely on it being defined. This header is included, under conditions or not, by various archs or famillies of archs / SoCs. However, it is very possible that boards based on those SoCs will not have a physical ethernet connector at all, even if the have a MAC; for example, the Nanopi Neo AIR (sunxi H3) does not. It is also possible that network booting is absolutely not necessary for a device. However, it is not possible to disable the PXE command, as it is forcibly enabled and is non-configurable. But it turns out we already have a config option to build a distro-ready image, in the name of DISTRO_DEFAULTS. Move CMD_PXE out of the hard-coded config_distro_defaults.h into a Kconfig option, that gets selected by DISTRO_DEFAULTS when it is set. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Joe Hershberger <joe.hershberger@ni.com> [trini: Make it select MENU, run moveconfig.py] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-24Move CONFIG_SYS_HUSH_PARSER to Kconfig for last 4 boardsMasahiro Yamada
I still see some defines of this config in board headers. Move them to defconfigs (+ renaming to CONFIG_HUSH_PARSER) to complete this migration. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-13armv8: s32v234: Introduce basic support for s32v234evbEddy Petrișor
Add initial support for NXP's S32V234 SoC and S32V234EVB board. The S32V230 family is designed to support computation-intensive applications for image processing. The S32V234, as part of the S32V230 family, is a high-performance automotive processor designed to support safe computation-intensive applications in the area of vision and sensor fusion. Code originally writen by: Original-signed-off-by: Stoica Cosmin-Stefan <cosminstefan.stoica@freescale.com> Original-signed-off-by: Mihaela Martinas <Mihaela.Martinas@freescale.com> Original-signed-off-by: Eddy Petrișor <eddy.petrisor@gmail.com> Signed-off-by: Eddy Petrișor <eddy.petrisor@nxp.com>
