path: root/include/configs/rsk7269.h
2014-11-13sh: move CONFIG_{SH2, SH2A, SH3, SH4} to KconfigMasahiro Yamada
This commit moves CONFIG_SH2, CONFIG_SH2A, CONFIG_SH3, CONFIG_SH4 to Kconfig renaming into CONFIG_CPU_SH2, CONFIG_CPU_SH2A, CONFIG_CPU_SH3, CONFIG_CPU_SH4, respectively because arch/sh/Kconfig of Linux uses CONFIG_CPU_SH* convention. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: sh2: Change CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQNobuhiro Iwamatsu
CONFIG_SYS_HZ of SH2 is not used as frequency of base timer. This is the correct clock of CMT. This changes from CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQ, in order to use CONFIG_SYS_HZ as clock of CMT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-01-08sh: sh2: remove CONFIG_SH2 definition from board configNobuhiro Iwamatsu
CONFIG_SH2 was already defined in arch/sh/sh2/config.mk. This removes CONFIG_SH2 from board config files of SH2. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-05-28sh: Add SH7269 device and RSK2+SH7269 boardPhil Edworthy
This is an sh2a device (max 266MHz) with FPU, video display controller (VDC), 8 serial ports, 4 I2C channels, 3 CAN ports, SD and on-chip USB. The RSK2+SH7269 board uses the SH7269 processor. It is often referred to as just rsk7269. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
