path: root/include/configs/rsk7264.h
2014-11-13sh: move CONFIG_{SH2, SH2A, SH3, SH4} to KconfigMasahiro Yamada
This commit moves CONFIG_SH2, CONFIG_SH2A, CONFIG_SH3, CONFIG_SH4 to Kconfig renaming into CONFIG_CPU_SH2, CONFIG_CPU_SH2A, CONFIG_CPU_SH3, CONFIG_CPU_SH4, respectively because arch/sh/Kconfig of Linux uses CONFIG_CPU_SH* convention. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: sh2: Change CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQNobuhiro Iwamatsu
CONFIG_SYS_HZ of SH2 is not used as frequency of base timer. This is the correct clock of CMT. This changes from CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQ, in order to use CONFIG_SYS_HZ as clock of CMT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-01-08sh: sh2: remove CONFIG_SH2 definition from board configNobuhiro Iwamatsu
CONFIG_SH2 was already defined in arch/sh/sh2/config.mk. This removes CONFIG_SH2 from board config files of SH2. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-03-08sh: Fix sh7264 clock speed and related serial settingPhil Edworthy
The generalised calculation of the serial bit rate reg also applies to sh7264, it was just the clock speed that was set incorrectly. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Clean up rsk7264 board settingsPhil Edworthy
Adjusted default settings so that we can boot zImages and uImages. Removed unused settings, use default commands and where possible calculate all other settings. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
