path: root/include/configs/rpi.h
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-29config: enable DFU over USB on Raspberry Pi4 boardsMarek Szyprowski
Enable support for DFU over USB. This requires to enable USB gadget, DWC2 UDC OTG driver and DFU command. DFU entities are defined for the following firmware objects: u-boot.bin, uboot.env, config.txt, and zImage/Image. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-11-25Merge tag 'rpi-next-2020.01' of https://github.com/mbgg/u-bootTom Rini
- add RPi4 upstream compatible to pinctrl - fix boot banner on RPi3/4 - add support for one binary on RPi3/4
2019-11-24ARM: bcm283x: Move BCM283x_BASE to a global variableMatthias Brugger
We move the per SOC define BCM283x_BASE to a global variable. This is a first step to provide a single binary for several bcm283x SoCs. Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-09-06rpi: increase SYS_BOOTM_LEN to 64M on ARM64Bonnans, Laurent
On AArch64, kernel images are not self-decompressing and easily exceed the 8MB limit. Signed-off-by: Laurent Bonnans <laurent.bonnans@here.com> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-02Add CONFIG_USE_PREBOOT to boards that use CONFIG_PREBOOTSimon Glass
In order to use CONFIG_PREBOOT with Kconfig, CONFIG_USE_PREBOOT must be defined for each board. To prepare for conversion to Kconfig, add this. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-06-12Fix compilation error if CONFIG_USB is disabledakaher
This patch is to fix the following compilation error when disabling CONFIG_USB for Rpi3: include/config_distro_bootcmd.h:242:2: error: expected ‘}’ before ‘BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB’ BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB Signed-off-by: Ajay Kaher <akaher@vmware.com> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2018-12-02rpi: Add mmc 1 as a boot targetEmmanuel Vadot
When booting with the rpi-firmware "mmc" overlay that disable the SDHOST controller and use the SDHCI one for the sd card, mmc 1 because a viable boot target. Add it to the list Signed-off-by: Oleksandr Tymoshenko <gonzo@FreeBSD.org> Signed-off-by: Emmanuel Vadot <manu@freebsd.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-06-03rpi: Fix fdt_high & initrd_high for 64-bit buildsTuomas Tynkkynen
The magic value that disables relocation is dependent on the CPU word size, so the current 'ffffffff' is doing the wrong thing on aarch64. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-05-24rpi: Change load addresses to make more room for the kernel & DTBTuomas Tynkkynen
As of Linux 4.16, a multiplatform AArch64 kernel with our distro config takes 26M. The current space reservation leaves only 17M for the kernel and if it goes over it, the initrd gets overwritten when loading the kernel from the filesystem. A similar problem happens on ARMv7 with the DTBs taken from the downstream Raspberry Pi foundation kernel. I guess they compile them with DT overlay support enabled which grows them just enough. Fix both of these problems by rewriting the memory map, which now allows kernels to be up to 36M and DTBs up to 1M. Also the comment block was kind of obsolete ever since the introduction of AArch64 support and the firmware-loaded DTB doesn't get placed at 0x100 anymore either, so that is fixed as well. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-05-23rpi: Adjust fdt_addr_r to a sane addressAlexander Graf
Back in the old days, 0x100 was used as the address to pass the device tree from firmware into the kernel. This has since changed to a more dynamic location, so using 0x100 actually breaks more things than it helps with. Let's move the device tree default location for distro boot to a more sane place that gives us enough head room in low memory. Reported-by: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-28bcm2835_mu_serial: Convert to KconfigAlexander Graf
Setting config options using headers is deprecated. This patch converts the BCM2835 Mini-UART to Kconfig. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl01x: Convert CONFIG_PL01X_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl01x. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28rpi: Determine PL011/Mini-UART availability at runtimeAlexander Graf
Firmware on the Raspberry Pi family of devices can dynamically configure either the PL011, Mini-UART or no device at all to be routed to the user accessible UART pins. That means we need to always include both drivers, because we can never be sure which of the two serial devices firmware actually chooses to use. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-04add support for Raspberry Pi Zero WDmitry Korunov
Signed-off-by: Dmitry Korunov <dessel.k@gmail.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09dm: video: arm: rpi: Convert to use driver model for videoSimon Glass
Adjust the video driver to work with driver model and move over existing baords. There is no need to keep the old code. We can also drop setting of CONFIG_FB_ADDR since driver model doesn't have this problem. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2017-05-09dm: arm: rpi: Move to driver model for USBSimon Glass
Start using driver model for USB on the Raspberry Pi. The dwc2 supports this now so this is just a config change. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09arm: rpi: Drop CONFIG_CONS_INDEXSimon Glass
This is not needed now that serial uses driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27clean-up: Remove uselsess mentions of CONFIG_COMMAND_HISTORYAlexey Brodkin
These were reminders that somehow slipped through the cracks or were erroneously introduced after previous clean-ups. Getting rid of then once again. Hopefully for good now :) Where missing and appropriate replace with CONFIG_CMDLINE_EDITING which really enables shell history as of now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Peter Griffin <peter.griffin@linaro.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Jon Mason <jon.mason@broadcom.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28Revert "arm: Remove unregister MACH_TYPE_xxx uses"Tom Rini
This reverts commit 70b26cd057f42c7126088b49d4285955c8a00eae. This is not a strict revert as it is easier to fix board/atmark-techno/armadillo-800eva/armadillo-800eva.c to now the correct name (same value) than to revert that change too. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-14arm: Remove unregister MACH_TYPE_xxx usesTom Rini
Before we can sync with the latest mach-types.h file from the Linux Kernel we need to remove some instances of MACH_TYPE_xxx from our sources. As these values have been removed from the canonical upstream source we should not be using them either, so drop. Cc: Tom Warren <twarren@nvidia.com> Cc: Lucas Stach <dev@lynxeye.de> Cc: Luka Perkov <luka@openwrt.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Heiko Schocher <hs@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Lucile Quirion <lucile.quirion@savoirfairelinux.com> Cc: Matthias Weisser <weisserm@arcor.de> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Nick Thompson <nick.thompson@gefanuc.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Erik van Luijk <evanluijk@interact.nl> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-29mmc: move MMC_SDHCI_IO_ACCESSORS to KconfigMasahiro Yamada
This is a user-unconfigurable option that is selected by the drivers that need to overwrite SDHCI IO memory accessors. (BCM2835 SDHCI seems the only driver that needs to do so.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-11-28bcm2835 video: Map frame buffer as 32bppAlexander Graf
To enable working efifb support, let's map the frame buffer as 32bpp instead of 16bpp. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
