path: root/include/configs/rpi.h
2015-02-21rpi: add support for Raspberry Pi 2 model BStephen Warren
USB doesn't seem to work yet; the controller detects the on-board Hub/ Ethernet device but can't read the descriptors from it. I haven't investigated yet. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21bcm2835/rpi: add SPDX license tags for some filesStephen Warren
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Move Raspberry Pi driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config header and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11dm: rpi: Move serial to driver modelSimon Glass
Adjust the configuration to use the driver model version of the pl01x serial driver. Add the required platform data. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-08ARM: rpi: support an environmentStephen Warren
Enable ENV_IS_IN_FAT so that the environment can be stored persistently. It's stored in the FAT partition that the RPi firmware requires. On most RPis, this is on the SD card (which must be present in order for the system to boot). On the CM this is on the built-in eMMC device. Since we now have a persistent environment, there's no need to load uEnv.txt at boot; we only did that to work around the lack of persistent environment. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08ARM: rpi: rename rpi_b to rpiStephen Warren
The U-Boot port runs on a variety of RPi models, not just the B. So, rename the port to something slightly more generic. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
