path: root/include/configs/rpi-common.h
2016-02-15ARM: rpi: set initrd_highLubomir Rintel
The kernel gets much too sad when the ramdisk is loaded too high into the 1GiB of memory on Raspberry Pi 2: ## Flattened Device Tree blob at 00000100 Booting using the fdt blob at 0x000100 Loading Ramdisk to 39c14000, end 3ab45067 ... OK Using Device Tree in place at 00000100, end 000045ea ... [ 0.599346] Unpacking initramfs... [ 0.602924] Unable to handle kernel paging request at virtual address f9c14000 Placement of the device tree was fixed in 89ca1000 (ARM: rpi: set fdt_high in the default environment). Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2016-02-08ARM: rpi: set fdt_high in the default environmentStephen Warren
The ARM Linux kernel requires the DT to be in memory accessible early during the boot process. This always happens naturally on the RPi 1, since the maximum memory size of 512MiB, and additionally some of that is reserved for use by the GPU. The RPi 2 has 1GiB of RAM (minus some GPU usage), and so if the DT is relocated to the top of RAM, Linux cannot access it. Prevent this from happening by setting fdt_high. Cc: Daniel Stone <daniels@collabora.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2016-02-08ARM: rpi: update memory layout env. var. documentationStephen Warren
Update rpi-common.h's documentation that describes the rationale for choosing various addresses for standardized variables used by boot scripts. This comment was correct when written, but not updated when some of the values were changed. Fixes: 14006a567105 ("rpi: set fdt_addr_r to 0x00000100 to match default ...device_tree_address") Cc: Jonathan Liu <net147@gmail.com> Cc: Daniel Stone <daniels@collabora.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2016-01-23ARM: rpi: enable USB keyboardStephen Warren
Now that the DWC2 driver supports split transactions, we can reasonably enable support for USB keyboards. This wasn't terribly useful before since keyboards are usually LS/FS devices, and thus require split transaction support when attached to a USB hub such as the hub built into the RPi model Bs. Cc: Stefan BrĂ¼ns <stefan.bruens@rwth-aachen.de> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-10-24ARM: rpi: Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG supportGuillaume GARDET
Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG support and enable it to set 'board_rev' and 'board_name' envs. 'board_rev' can be used in scripts to determine what board we are running on and 'board_name' for pretty printing. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-08-28rpi: set fdt_addr_r to 0x00000100 to match default device_tree_addressJonathan Liu
Raspberry Pi by default loads the FDT to 0x00000100 so set fdt_addr_r to match and move scriptaddr to 0x02000000 to avoid clobbering the FDT. Signed-off-by: Jonathan Liu <net147@gmail.com>
2015-08-12arm/rpi: Enable dcacheAlexander Stein
Now that mailbox driver supports cache flush and invalidation, we can enable dcache. Signed-off-by: Alexander Stein <alexanders83@web.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2015-05-28ARM: bcm283x: Switch to generic timerMarek Vasut
Switch to generic timer implementation from lib/time.c . This also fixes a signed overflow which was in __udelay() implementation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Tyler Baker <tyler.baker@linaro.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21rpi: add support for Raspberry Pi 2 model BStephen Warren
USB doesn't seem to work yet; the controller detects the on-board Hub/ Ethernet device but can't read the descriptors from it. I haven't investigated yet. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
