path: root/include/configs/rmu.h
2011-12-08MPC850: remove obsolete "rmu" BoardWolfgang Denk
The "rmu" board has long been unmaintained, and is broken. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-10rmu board: fix error: 'CONFIG_ENV_SECT_SIZE' undeclaredWolfgang Denk
2008-08-06Fix merge problemsStefan Roese
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various q* and r* named board ↵Jon Loeliger
config files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-04-08* Patch by Mark Jonas: Remove config.tmp files only whenwdenk
unconfiguring the board * Adapt RMU board for bigger flash memory * Test fix for ethernet problems on MPC5200
2003-12-03* Enabled password check on RMU boardwdenk
* Fix configuration problem with IceCube in LOWBOOT configuration: environment got embedded, corrupting the image layout.
2003-08-29Add I2C and RTC support for RMU board using software I2C driverwdenk
(because of better response to iprobe command); fix problem with "reset" command
2003-08-28* Fix ICU862 environment problemwdenk
* Fix RAM size detection for RMU board * Implement "reset" for MGT5100/MPC5200 systems
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
