The "rmu" board has long been unmaintained, and is broken.
Remove it.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
CONFIG_BOOTP_MASK.
config files.
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
enable SNTP support in some boards.
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
* Fix configuration problem with IceCube in LOWBOOT configuration:
environment got embedded, corrupting the image layout.
(because of better response to iprobe command); fix problem with
"reset" command
* Fix RAM size detection for RMU board
* Implement "reset" for MGT5100/MPC5200 systems
* Add support for TQM862L at 100/50 MHz
* Patch by Pantelis Antoniou, 02 Jun 2003:
major reconstruction of networking code;
add "ping" support (outgoing only!)
