path: root/include/configs/rk3288_common.h
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-08-05rockchip: add usb mass storage feature support for rk3288Xu Ziyuan
Enable ums feature for rk3288 boards, so that we can mount the mmc device to PC. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-05rockchip: add basic partitions support for rk3288Xu Ziyuan
For compatibility with distro boot, fastboot, and mount the mmc deivce to PC via usb mass storage feature, GPT partitions are essential. You should write the partitions to mmc device prior to use above feature. => gpt write mmc 1 $partitions GPT successfully written to block device! success! Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: rk3288: revise CONFIG_FASTBOOT_BUF_ADDRjk.kernel@gmail.com
CONFIG_SYS_LOAD_ADDR is absolutely safe to store image for fastboot. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: remove the duplicated macro configjk.kernel@gmail.com
CONFIG_DOS_PARTITION and CONFIG_EFI_PARTITION are already included in config_distro_defaults.h, and we don't need them in SPL stage. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: rk3288: disable fastboot in SPL stagejk.kernel@gmail.com
Reduce compilation time for SPL. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31configs: rockchip: remove no use MACROKever Yang
The CONFIG_ROCKCHIP_COMMON and CONFIG_SPL_ROCKCHIP_COMMON are no use now, remove them. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: rk3288: add fastboot supportXu Ziyuan
Enable fastboot feature on rk3288. This path doesn't support the fastboot flash function command entirely. We will hit "cannot find partition" assertion without specified partition environment. Define gpt partition layout in specified board such as firefly-rk3288, then enjoy it! Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: add option to change method of loading u-bootXu Ziyuan
If we would like to boot from SD card, we have to implement mmc driver in SPL stage, and get a slightly large SPL binary. Rockchip SoC's bootrom code has the ability to load spl and u-boot, then boot. If CONFIG_ROCKCHIP_SPL_BACK_TO_BROM is enabled, the spl will return to bootrom in board_init_f(), then bootrom loads u-boot binary. Loading sequence after rework: bootrom ==> spl ==> bootrom ==> u-boot Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed up spelling of U-Boot, boorom, opinion->option, Rochchip: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-11rockchip: Disable CONFIG_SDHCISimon Glass
This option is not actually needed for rockchip boards. Drop it, since it will not support driver-model MMC operation support. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-27rockchip: Drop SPL GPIO support for rk3288Simon Glass
This is not currently used and saves a little over 1KB of SPL image size. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-31armv7: add cacheline sizes where missingAlbert ARIBAUD
Some armv7 targets are missing a cache line size declaration. In preparation for "arm: cache: Implement cache range check for v7" patch, add these declarations with the appropriate value for the target's SoC or CPU. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-21rockchip: config: Enable the 'gpio' commandSimon Glass
Now that we have a pretty good GPIO driver, enable the 'gpio' command on all rockchip boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Don't skip low-level initSimon Glass
At present the low-level init is skipped on rockchip. Among other things this means that the instruction cache is left disabled. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Enable the Chrome OS ECSimon Glass
Turn on the EC and enable the keyboard. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Use pwrseq for MMC start-up on jerrySimon Glass
This is defined in the device tree in Linux. Copy over the settings so that this can be used instead of hard-coding the reset line. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: move SYS_MALLOC_SIMPLE to mach-rockchip KconfigAriel D'Alessandro
Commit 1eb0c03c2198a7ec9de456b83dacdc4831b96cbf added SPL_SYS_MALLOC_SIMPLE Kconfig option and changed the way it is evaluated. Thus, the definitions of CONFIG_SYS_MALLOC_SIMPLE in rk3***_common.h board configs are now incorrect because CONFIG_SPL_BUILD is enabled so CONFIG_IS_ENABLED(SYS_MALLOC_SIMPLE) will look for SPL_SYS_MALLOC_SIMPLE instead of SYS_MALLOC_SIMPLE. This commit fix this enabling SPL_SYS_MALLOC_SIMPLE with the new Kconfig option by default in rockchip-mach. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: add config decide whether to build common.chuang lin
some rockchips soc will not use uclass in SPL stage, so define config to decide whether to build common.c Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: add timer driverhuang lin
some rockchip soc will not include lib/timer.c in SPL stage, so implement timer driver for some soc can use us delay function in SPL. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: firefly: Save the environment on SD cardSjoerd Simons
Save the environment on the SD card for Firefly in the empty space between the SPL and the u-boot image. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: Also load the initrd below 512MSjoerd Simons
Similar to load an fdt, when loading an initrd about the 512Mb mark things seem to break. For now force loading below 512Mb until the reason why this fails has been determined/solved. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add config_distro_bootcmd supportSjoerd Simons
Now that MMC works in U-Boot add config distro command support to start Linux in a standard fashion. One oddity here is that linux fails to load when the fdt is relocated to above 512MB, so set fdt_high to make sure it's loaded below that. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add basic support for firefly-rk3288Simon Glass
The Firefly RK3288 is a suitable target board for initial mainline Rockchip support. It includes a good set of peripherals, a recent SoC and it is readily available. This adds only some basic files required to allow the baord to display a serial message in SPL and hang. Signed-off-by: Simon Glass <sjg@chromium.org>
