This board has not been converted to generic board by the deadline.
Remove it.
them from include/configs.
Becuase the board select menu in arch/arm/Kconfig is too big,
move the KirkWood board select menu to kirkwood/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="kirkwood").
Acked-by: Prafulla Wadasdkar <prafulla@marvell.com>
Cc: Luka Perkov <luka@openwrt.org>
[trini: Fixup common/cmd_io.c]
It is observed that, in most of the board configs the code is being
duplicated, also for any common change all board files needs update
This issue was under discussion from long on mailing list and we
converge on introducing common config file.
With this patch-
1. Total Kirkwood specific configuration code is reduced by 210 lines
2. All common configuration can be shared by multiple boards
3. Easy to manage common updates like ARM relocation changes
mv-common.h file is added to include/configs/
It contains all common configuration supported for all Kirkwood boards
The respective board configs are updated for its usage
Build tested for guruplug, mv88f6281gtw_ge, openrd_base,
rd6281a and sheevaplug
Binary execution tested for sheevaplug
Todo:
1. Other custom Kirkwood boards to be synced
2. The support to be extended for Orion5X based boards
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Rename all references to kirkwood in mvgbe symbols
throughout the whole codebase.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
It is recommended to define the macro CONFIG_SYS_64BIT_VSPRINTF
for NAND specific warning removal, same is done in this patch
This is Marvell's 88F6281_A0 based reference design board
This patch is tested for-
1. Boot from DRAM/NAND flash/NFS
2. File transfer using tftp and loadb
3. NAND flash read/write/erase
