path: root/include/configs/rastaban.h
2016-09-16Convert CONFIG_SPL_NET_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_NET_VCI_STRING to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPL_NET_VCI_STRING Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_ETH_SUPPORT to KconfigSimon Glass
2016-06-09siemens,am33x: add draco etamin boardHeiko Schocher
In the draco CPU board family, etamin is a new variant with bigger flash and more RAM. Due to new flash that uses larger pages (4K) some changes are necessary because it impacts the MTD partition layout and the ubi mount parameters. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Move BOOTDELAY into defconfig, just always be 3 now] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-19siemens,am33x,rastaban: add rastaban configHeiko Schocher
rastaban is a draco version with more flash, more RAM and faster CPU. Number of partitions is the same but rootfs partition is different. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
