path: root/include/configs/r7780mp.h
2008-08-13serial: move CFG_SCIF_CONSOLE to CONFIG_SCIF_CONSOLEJean-Christophe PLAGNIOL-VILLARD
move also conditional compilation to Makefile Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-07sh: Update Renesas R7780MP boardNobuhiro Iwamatsu
New NOR Flash board support and remove network setting from config file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Move SuperH PCI driver from cpu/sh4 to drivers/pciNobuhiro Iwamatsu
2008-03-28sh: Add support Renesas Solutions R7780MPYusuke Goda
Renesas Solutions R7780MP is a reference board on SH7780. This board has serial, 10/100 base Ethernet deivice, CF slot and VGA devices. This board can set extension board. Extension board has 10/100/1000 base Ethernet device, PCI slot, S-ATA, iDVR slot. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
