path: root/include/configs/r2dplus.h
2014-01-08sh: sh4: remove CONFIG_SH4 definition from board configNobuhiro Iwamatsu
CONFIG_SH4 was already defined in arch/sh/sh4/config.mk. This removes CONFIG_SH4 from board config files of SH4. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-19CMD: Drop CONFIG_CMD_DFL, it's not usedMarek Vasut
$ git grep CMD_DFL board/atc/ti113x.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/atc/ti113x.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); board/cpc45/pd67290.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/cpc45/pd67290.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); drivers/pcmcia/i82365.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ drivers/pcmcia/i82365.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); include/configs/MBX.h:#define CONFIG_CMD_DFL include/configs/MigoR.h:#define CONFIG_CMD_DFL include/configs/digsy_mtc.h:#define CONFIG_CMD_DFL include/configs/ms7722se.h:#define CONFIG_CMD_DFL include/configs/ms7750se.h:#define CONFIG_CMD_DFL include/configs/r2dplus.h:#define CONFIG_CMD_DFL include/configs/sh7757lcr.h:#define CONFIG_CMD_DFL include/configs/sh7785lcr.h:#define CONFIG_CMD_DFL Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pfister_Werner@intercontrol.de Cc: iwamatsu@nigauri.org Cc: nobuhiro.iwamatsu.yj@renesas.com Cc: vapier@gentoo.org Cc: wd@denx.de Cc: yoshihiro.shimoda.uh@renesas.com Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-02-02sh: Remove config.mk for r2dplus boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-11sh: r2dplus: Add support zimagebootNobuhiro Iwamatsu
2010-08-08ide: add configurationAlbert Aribaud
CONFIG_IDE_SWAP_IO This configuration option replaces a complex conditional in cmd_ide.c with an explicit define to be added to SoC or board configs. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2009-07-13Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-08sh3/sh4: rename config option TMU_CLK_DIVIDER to CONFIG_SYS_TMU_CLK_DIVJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh3/sh4: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
2009-03-12sh: Fix cannot work rtl8139 on r2dplusYoshihiro Shimoda
The rtl8139 driver use pci_mem_to_phys. So it need PCI system memory registration. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-13serial: move CFG_SCIF_CONSOLE to CONFIG_SCIF_CONSOLEJean-Christophe PLAGNIOL-VILLARD
move also conditional compilation to Makefile Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-07sh: Update Renesas R2DPlus boardNobuhiro Iwamatsu
New NOR Flash board support and remove old type flash board config. And Remove network setting from config file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support Renesas Solutions R2D plus boardNobuhiro Iwamatsu
R2D plus is SH reference board used with SH7751R. This board has 266Mhz CPU, 64MB SDRAM, Cardbus, CF interface, one PCI bus, VGA, and two Ethernet controller. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
