path: root/include/configs/r2dplus.h
2017-09-03include/configs: remove default values of CONFIG_SYS_BARGSIZEThomas Petazzoni
CONFIG_SYS_BARGSIZE is already defined to 512 in common/image.c when not defined. Therefore, there is no point in having board configuration files define it to 512. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SH_ZIMAGEBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SH_ZIMAGEBOOT Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-02r2dplus: fixup CONFIG_SYS_TEXT_BASE to account arch/sh changesVladimir Zapolskiy
This change allows to reserve enough space at the end of board SDRAM to store two copies of U-Boot and malloc heap. Due to selection of the CONFIG_SYS_TEXT_BASE the second code/data copying is not avoided, first of all this may depend on a used toolchain, secondly at this point some level of volatility is wanted to do more platform changes and do not care about probably changed calculated in runtime relocation offset. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-12-02sh: define CONFIG_DISPLAY_BOARDINFO to print board informationVladimir Zapolskiy
All SH boards define a checkboard() function which outputs basic board information on boot, however generic board support requires to define CONFIG_DISPLAY_BOARDINFO to do that, so define it for the boards. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: remove undefined DEBUG preprocessor token from board config filesVladimir Zapolskiy
By default this undef is a noop, moreover at this point when the platform support is broken is prevents debugging of U-boot by manual insertion of #define DEBUG into common files, so it makes sense to remove the option from all SH boards as a harmful one. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02r2dplus: use P1 area space for text base and PCI system memoryVladimir Zapolskiy
While both options are acceptable use P1 area physical addresses instead of external memory space of text base and PCI system memory for unification purposes, all other supported superh boards have the same selection. This allows to easily ensure that CONFIG_SYS_TEXT_BASE is located within available DRAM. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: remove __io config options from r2dplus and r7780mp boardsVladimir Zapolskiy
Defined __io is no-op for the SH architecture and it can be removed from board files without any functional change. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-22net: Move CONFIG_RTL8139 to KconfigBin Meng
Introduce CONFIG_RTL8139 in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [trini: Fixup MPC8641HPCN* and r2dplus configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-01-08sh: sh4: remove CONFIG_SH4 definition from board configNobuhiro Iwamatsu
CONFIG_SH4 was already defined in arch/sh/sh4/config.mk. This removes CONFIG_SH4 from board config files of SH4. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-19CMD: Drop CONFIG_CMD_DFL, it's not usedMarek Vasut
$ git grep CMD_DFL board/atc/ti113x.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/atc/ti113x.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); board/cpc45/pd67290.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/cpc45/pd67290.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); drivers/pcmcia/i82365.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ drivers/pcmcia/i82365.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); include/configs/MBX.h:#define CONFIG_CMD_DFL include/configs/MigoR.h:#define CONFIG_CMD_DFL include/configs/digsy_mtc.h:#define CONFIG_CMD_DFL include/configs/ms7722se.h:#define CONFIG_CMD_DFL include/configs/ms7750se.h:#define CONFIG_CMD_DFL include/configs/r2dplus.h:#define CONFIG_CMD_DFL include/configs/sh7757lcr.h:#define CONFIG_CMD_DFL include/configs/sh7785lcr.h:#define CONFIG_CMD_DFL Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pfister_Werner@intercontrol.de Cc: iwamatsu@nigauri.org Cc: nobuhiro.iwamatsu.yj@renesas.com Cc: vapier@gentoo.org Cc: wd@denx.de Cc: yoshihiro.shimoda.uh@renesas.com Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-02-02sh: Remove config.mk for r2dplus boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-11sh: r2dplus: Add support zimagebootNobuhiro Iwamatsu
2010-08-08ide: add configurationAlbert Aribaud
CONFIG_IDE_SWAP_IO This configuration option replaces a complex conditional in cmd_ide.c with an explicit define to be added to SoC or board configs. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2009-07-13Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-08sh3/sh4: rename config option TMU_CLK_DIVIDER to CONFIG_SYS_TMU_CLK_DIVJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh3/sh4: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
2009-03-12sh: Fix cannot work rtl8139 on r2dplusYoshihiro Shimoda
The rtl8139 driver use pci_mem_to_phys. So it need PCI system memory registration. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-13serial: move CFG_SCIF_CONSOLE to CONFIG_SCIF_CONSOLEJean-Christophe PLAGNIOL-VILLARD
move also conditional compilation to Makefile Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
