path: root/include/configs/quantum.h
2008-07-31Fix printf() format problems with configurable promptsWolfgang Denk
U-Boot allows for configurable prompt strings using the CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far, the assumption was that any such user defined problts would contain exactly one "%d" format specifier. But some boards did not. To allow for flexible boot prompts without adding too complex code we now allow to specify the whole list of printf() arguments in the user definition. This is powerful, but requires a responsible user who really understands what he is doing, as he needs to know for exanple which variables are available in the respective context. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various q* and r* named board ↵Jon Loeliger
config files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-09-29* Patch by Shlomo Kut, 29 Mar 2004:wdenk
Add support for MKS Instruments "Quantum" board * Fix build problem with Cogent boards; avoid using <asm/byteorder.h> when using the host compiler
