path: root/include/configs/qemu-x86.h
2017-08-01x86: Switch all boards to use DM SCSIBin Meng
After MMC is converted to DM, convert to use DM SCSI as well for all x86 boards and imply BLK for both MMC and SCSI drivers. CONFIG_SCSI_DEV_LIST is no longer used. Clean them up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: Convert INTEL_ICH6_GPIO to KconfigBin Meng
This converts Intel ICH6 GPIO driver to Kconfig, and add it to the imply list of platform drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-07x86: qemu: Add build options for SPLBin Meng
If SPL is used we want to use the generic SPL framework and boot from SPI via a board-specific means. Add these options to the board config file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-25Convert CONFIG_ARCH_EARLY_INIT_R to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_EARLY_INIT_R Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-12x86: Convert to use DM VESA video driverBin Meng
At present only chromebook boards are converted to DM video. Other x86 boards are still using the legacy cfb_console driver. This switches to use DM version drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-24dm: x86: Set up interrupt routing from interrupt_init()Simon Glass
At present interrupt routing is set up from arch_misc_init(). We can do it a little later instead, in interrupt_init(). This removes the manual pirq_init() call. Where the platform does not have an interrupt router defined in its device tree, no error is generated. Some platforms do not have this. Drop pirq_init() since it is no-longer used. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19x86: qemu: Convert to use driver model keyboardBin Meng
Convert to use driver model keyboard on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: Remove CONFIG_SYS_EARLY_PCI_INITBin Meng
CONFIG_SYS_EARLY_PCI_INIT is not needed any more since with driver model, PCI enumeration is automatically triggered. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model pciBin Meng
Move to driver model for pci on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Move chipset-specific codes from pci.c to qemu.cBin Meng
Move chipset-specific codes such as PAM init, PCIe ECAM and MP table from pci.c to qemu.c, to prepare for DM PCI conversion. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-26x86: Enable CONFIG_PCI_CONFIG_HOST_BRIDGE for all boardsBin Meng
It looks that x86 chipset always contains a host bridge at pci b.d.f 0.0.0, so enable this for all boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: Move CONFIG_X86_SERIAL to KconfigSimon Glass
Move this config option to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-04x86: qemu: Implement PIRQ routingBin Meng
Support QEMU PIRQ routing via device tree on both i440fx and q35 platforms. With this commit, Linux booting on QEMU from U-Boot has working ATA/SATA, USB and ethernet. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Make host bridge (b.d.f=0.0.0) visibleBin Meng
The default weak version of pci_skip_dev() in drivers/pci/pci_common.c skips the host bridge (b.d.f = 0.0.0) which is actually the i440fx/q35 chipset for QEMU targets. Define CONFIG_PCI_CONFIG_HOST_BRIDGE to make it visible in the PCI configuration space. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Add ATA/SATA supportBin Meng
Enable legacy IDE support on the pc target and AHCI support on the q35 target. Default configuration is to support the pc target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Add graphics supportBin Meng
It turns out that QEMU x86 emulated graphic card has a built-in option ROM which can be run perfectly with native mode by U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Set CONFIG_NR_DRAM_BANKS to 8 and move it to x86-common.hBin Meng
Some x86 boards set CONFIG_NR_DRAM_BANKS to 1, which causes incorrect DRAM size printed when booting from coreboot, like this: CPU: x86, vendor Intel, device 663h DRAM: 636 KiB Using default environment Change it to 8 which should be enough for both coreboot and bare cases, and move it to x86-common.h. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Support QEMU x86 targetsBin Meng
This commit introduces the initial U-Boot support for QEMU x86 targets. U-Boot can boot from coreboot as a payload, or directly without coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Merged in patch 'x86: qemu: Add CMD_NET to qemu-x86_defconfig https://patchwork.ozlabs.org/patch/479745/
