path: root/include/configs/qemu-x86.h
2015-08-26x86: Enable CONFIG_PCI_CONFIG_HOST_BRIDGE for all boardsBin Meng
It looks that x86 chipset always contains a host bridge at pci b.d.f 0.0.0, so enable this for all boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: Move CONFIG_X86_SERIAL to KconfigSimon Glass
Move this config option to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-04x86: qemu: Implement PIRQ routingBin Meng
Support QEMU PIRQ routing via device tree on both i440fx and q35 platforms. With this commit, Linux booting on QEMU from U-Boot has working ATA/SATA, USB and ethernet. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Make host bridge (b.d.f=0.0.0) visibleBin Meng
The default weak version of pci_skip_dev() in drivers/pci/pci_common.c skips the host bridge (b.d.f = 0.0.0) which is actually the i440fx/q35 chipset for QEMU targets. Define CONFIG_PCI_CONFIG_HOST_BRIDGE to make it visible in the PCI configuration space. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Add ATA/SATA supportBin Meng
Enable legacy IDE support on the pc target and AHCI support on the q35 target. Default configuration is to support the pc target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Add graphics supportBin Meng
It turns out that QEMU x86 emulated graphic card has a built-in option ROM which can be run perfectly with native mode by U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Set CONFIG_NR_DRAM_BANKS to 8 and move it to x86-common.hBin Meng
Some x86 boards set CONFIG_NR_DRAM_BANKS to 1, which causes incorrect DRAM size printed when booting from coreboot, like this: CPU: x86, vendor Intel, device 663h DRAM: 636 KiB Using default environment Change it to 8 which should be enough for both coreboot and bare cases, and move it to x86-common.h. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Support QEMU x86 targetsBin Meng
This commit introduces the initial U-Boot support for QEMU x86 targets. U-Boot can boot from coreboot as a payload, or directly without coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Merged in patch 'x86: qemu: Add CMD_NET to qemu-x86_defconfig https://patchwork.ozlabs.org/patch/479745/
