path: root/include/configs/qemu-ppce500.h
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-26Move CONFIG_PANIC_HANG to KconfigMasahiro Yamada
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_REGINFO to KconfigChristophe Leroy
This patch converts CONFIG_CMD_REGINFO to Kconfig Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Convert CONFIG_CMD_IRQ to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IRQ Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-04powerpc: E500: Move CONFIG_E500 and CONFIG_E500MC to KconfigYork Sun
Use Kconfig option for E500 and E500MC macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: QEMU_E500: Remove macro CONFIG_QEMU_E500York Sun
Replace CONFIG_QEMU_E500 with ARCH_QEMU_E500 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-04-20qemu-ppce500: Add support for 64bit CCSR mapAlexander Graf
QEMU 2.3 changes the address layout of the CCSR map in the PV ppce500 machine to reside in higher address space. Unfortunately, this exposed a glitch in u-boot for ppce500: While providing a function to dynamically evaluate the CCSR region's position in physical address space, we never used it. Plus we forgot to support 64bit physical addresses. This patch fixes that mishap, making u-boot work fine with latest QEMU again. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-13PPC 85xx QEMU: Make a generic board fileAlexander Graf
This patch enables the E500 QEMU board to use the generic cross-arch board infrastructure. Signed-off-by: Alexander Graf <agraf@suse.de>
2014-04-22PPC 85xx: Add qemu-ppce500 machineAlexander Graf
For KVM we have a special PV machine type called "ppce500". This machine is inspired by the MPC8544DS board, but implements a lot less features than that one. It also provides more PCI slots and is supposed to be enumerated by device tree only. This patch adds support for the generic ppce500 machine and tries to rely solely on device tree for device enumeration. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
