path: root/include/configs/qemu-mips64.h
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-21mips: qemu-mips/64: Expand malloc pool for CONFIG_SYS_BOOTPARAMS_LENKyle Edwards
Before this patch, CONFIG_SYS_BOOTPARAMS_LEN was the same size as CONFIG_SYS_MALLOC_LEN. So, if malloc() had previously been called, and initr_malloc_bootparams() was called, it would fail with an out-of- memory error. This patch fixes this issue by expanding the malloc pool to 256KB. Signed-off-by: Kyle Edwards <kyleedwardsny@gmail.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-04-21mips: qemu-mips/64: Remove obsolete CONFIG_SYS_MONITOR_LEN from configKyle Edwards
This fixes an issue with the saveenv command causing U-Boot to no longer work on the QEMU Mips pseudoboard. Because the offset of the environment was being determined by CONFIG_SYS_MONITOR_LEN, and this value was less than the actual size of U-Boot, saveenv was overwriting parts of the U-Boot code. Because CONFIG_SYS_MONITOR_LEN is no longer used on MIPS, this patch removes it and places the environment at the end of the pseudoboard's 4MB flash. Signed-off-by: Kyle Edwards <kyleedwardsny@gmail.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-31MIPS: Move cache sizes to KconfigPaul Burton
Move details of the L1 cache line sizes & total sizes into Kconfig, defaulting to 0. A new CONFIG_SYS_CACHE_SIZE_AUTO Kconfig entry is introduced to allow platforms to select auto-detection of cache sizes, and it defaults to being enabled if none of the cache sizes are set by the configuration (ie. sizes are all the default 0), and code is adjusted to #ifdef on that rather than on the definition of the sizes (which will always be defined even if 0). Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-21Use CONFIG_IDE_SWAP_IO when running on big-endian MIPS (32 or 64-bit) in ↵Stanislav Galabov
QEMU so that IDE transfers work properly Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-28generic-board: select SYS_GENERIC_BOARD for some architecturesMasahiro Yamada
We have done with the generic board conversion for all the boards of ARC, Blackfin, M68000, MicroBlaze, MIPS, NIOS2, Sandbox, X86. Let's select SYS_GENERIC_BOARD for those architectures, so we can tell which architecture has finished the conversion at a glance. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-11-27MIPS: qemu_mips: switch to generic boardDaniel Schwierzeck
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-03-07mips: move CONFIG_MIPS{32, 64} definition to config.mkMasahiro Yamada
All mips32 boards define CONFIG_MIPS32 in config headers except malta boards which define it in boards.cfg. We can consolidate them by defining it in arch/mips/cpu/mips32/config.mk. CONFIG_MIPS64 definition can be moved to arch/mips/cpu/mips64/config.mk as well. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-10-16MIPS: add board qemu-mips64 supportZhi-zhou Zhang
Both big-endian and little-endian are tested with below commands: Rom version: (Default, Now we config it as rom version) qemu-system-mips64el -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic qemu-system-mips64 -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic Ram version: qemu-system-mips64el -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic qemu-system-mips64 -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
