path: root/include/configs/qemu-mips.h
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-21mips: qemu-mips/64: Expand malloc pool for CONFIG_SYS_BOOTPARAMS_LENKyle Edwards
Before this patch, CONFIG_SYS_BOOTPARAMS_LEN was the same size as CONFIG_SYS_MALLOC_LEN. So, if malloc() had previously been called, and initr_malloc_bootparams() was called, it would fail with an out-of- memory error. This patch fixes this issue by expanding the malloc pool to 256KB. Signed-off-by: Kyle Edwards <kyleedwardsny@gmail.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-04-21mips: qemu-mips/64: Remove obsolete CONFIG_SYS_MONITOR_LEN from configKyle Edwards
This fixes an issue with the saveenv command causing U-Boot to no longer work on the QEMU Mips pseudoboard. Because the offset of the environment was being determined by CONFIG_SYS_MONITOR_LEN, and this value was less than the actual size of U-Boot, saveenv was overwriting parts of the U-Boot code. Because CONFIG_SYS_MONITOR_LEN is no longer used on MIPS, this patch removes it and places the environment at the end of the pseudoboard's 4MB flash. Signed-off-by: Kyle Edwards <kyleedwardsny@gmail.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-31MIPS: Move cache sizes to KconfigPaul Burton
Move details of the L1 cache line sizes & total sizes into Kconfig, defaulting to 0. A new CONFIG_SYS_CACHE_SIZE_AUTO Kconfig entry is introduced to allow platforms to select auto-detection of cache sizes, and it defaults to being enabled if none of the cache sizes are set by the configuration (ie. sizes are all the default 0), and code is adjusted to #ifdef on that rather than on the definition of the sizes (which will always be defined even if 0). Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-21Use CONFIG_IDE_SWAP_IO when running on big-endian MIPS (32 or 64-bit) in ↵Stanislav Galabov
QEMU so that IDE transfers work properly Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-28generic-board: select SYS_GENERIC_BOARD for some architecturesMasahiro Yamada
We have done with the generic board conversion for all the boards of ARC, Blackfin, M68000, MicroBlaze, MIPS, NIOS2, Sandbox, X86. Let's select SYS_GENERIC_BOARD for those architectures, so we can tell which architecture has finished the conversion at a glance. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-11-27MIPS: qemu_mips: switch to generic boardDaniel Schwierzeck
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-03-07mips: move CONFIG_MIPS{32, 64} definition to config.mkMasahiro Yamada
All mips32 boards define CONFIG_MIPS32 in config headers except malta boards which define it in boards.cfg. We can consolidate them by defining it in arch/mips/cpu/mips32/config.mk. CONFIG_MIPS64 definition can be moved to arch/mips/cpu/mips64/config.mk as well. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-10-16MIPS: qemu_mips.h: cleanup coding style and checkpatch.pl issuesDaniel Schwierzeck
2012-10-16MIPS: qemu_mips: move CONFIG_SYS_TEXT_BASE to qemu-mips.hZhi-zhou Zhang
We define CONFIG_SYS_TEXT_BASE in board's specified header file. So config.mk is useless, then remove it. Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com>
2012-08-24MIPS: add support for qemu for little endian MIPS32 CPUsDaniel Schwierzeck
Tested with 'qemu-system-mipsel -machine mips -bios u-boot.bin -nographic' Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2009-07-22Refresh LZMA-lib to v4.65Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
2008-12-17MIPS: qemu_mips: move env storage just after u-bootJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-06-05[MIPS] lib_mips/time.c: Fix CP0 count register usage and timer routinesShinya Kuribayashi
MIPS port has two problems in timer routines. One is now we assume CFG_HZ equals to CP0 counter frequency, but this is wrong. CFG_HZ has to be 1000 in the U-Boot system. The other is we don't have a proper time management counter like timestamp other ARCHs have. We need the 32-bit millisecond clock counter. This patch introduces timestamp and CYCLES_PER_JIFFY. timestamp is a 32-bit non-overflowing CFG_HZ counter, and CYCLES_PER_JIFFY is the number of calculated CP0 counter cycles in a CFG_HZ. STRATEGY: * Fix improper CFG_HZ value to have 1000 * Use CFG_MIPS_TIMER_FREQ for timer counter frequency, instead. * timer_init: initialize timestamp and set up the first timer expiration. Note that we don't need to initialize CP0 count/compare registers here as they have been already zeroed out on the system reset. Leave them as they are. * get_timer: calculate how many timestamps have been passed, then return base-relative timestamp. Make sure we can easily count missed timestamps regardless of CP0 count/compare value. * get_ticks: return the current timestamp, that is get_timer(0). Most parts are from good old Linux v2.6.16 kernel. v2: - Remove FIXME comments as they turned out to be trivial. - Use CP0 compare register as a global variable for expirelo. - Kill a global variable 'cycles_per_jiffy'. Use #define CYCLES_PER_JIFFY instead. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-04-25qemu-mips.h: Add CFI supportJean-Christophe PLAGNIOL-VILLARD
CONFIG_ENV_OVERWRITE is also added. This patch is originally created by Jean-Christophe PLAGNIOL-VILLARD. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-04-24qemu-mips: Cleanup whitespace, indentation, etc.Shinya Kuribayashi
No functional change. This patch was originally submitted by Jean-Christophe PLAGNIOL-VILLARD. Then I re-created from scratch, and changed more lines than the original. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2008-01-17qemu-mips: active HUSH PARSER, AUTO_COMPLETE and CMDLINE_EDITINGJean-Christophe PLAGNIOL-VILLARD
2008-01-17MIPS:Target support for qemu -M mipsVlad Lungu
With serial, NE2000, IDE support. Tested in big-endian mode. Memory size hard-coded to 128M for now, so don't play with the -m option. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
