Move this option to Kconfig and tidy up existing uses.
In the draco CPU board family, etamin is a new variant
with bigger flash and more RAM. Due to new flash that
uses larger pages (4K) some changes are necessary because
it impacts the MTD partition layout and the ubi mount
parameters.
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
[trini: Move BOOTDELAY into defconfig, just always be 3 now]
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
updates for the siemens am335x based boards:
- draco: add delay for DDR3 configuration
- change MTD partition layout and add a possibility
to redefine MTD layout in board header.
- move ubi support to common header file
- draco: improve dtb naming
- draco: set CONFIG_SYS_CBSIZE to 1024
- add generic env based led
Leds can now be defined in Environment
- add generic env based dfu button
Which gpio is used for the dfu button can be defined
through the Environment
- set MACH_TYPE only if defined
- draco: increase CPU freq to 300MHz
- Add time command to siemens am33xx boards
- DDR3: increase default tRFC
- draco: enable pullup for DFU and ERST pin
- change print format DDR3
Acked-by: Heiko Schocher <hs@denx.de>
add FIT support and set "boardid" from factoryset records
"DEV/id" and "COMP/ver". "boardid" is used for selecting
which fit configuration gets booted on the board.
For dxr2 board DXR2_IOCTRL_VAL is set by data in EEPROM. In pxm2
board it does not make sense to have dxr2 as prefix. Replace it with
more meaningful DDR prefix.
Cc: Pascal Bach <pascal.bach@siemens.com>
Cc: Roger Meier <r.meier@siemens.com>
Some platforms like AM437x have different EVMs with different phy addresses,
so this patch adds support for passing phy address via cpsw plaform data.
Also renamed phy_id to phy_addr so better understanding of the code.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
[trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335
pengwyn boards]
- dxr2: define unused pins as input
- do not enable RTC32K OSC on dxr2 board
- update default environment
- add splashpos=m,m to default environment, so splash screen is always
centered.
- adapt environment for bootcount feature
- add altbootcmd to default environment
- rut: SPL add early reset pulse for eth-phy, maXTouch and display
- rut: display timing aenderungen
- siemens boards: adapt for background color = white
- add boutcount feature for the siemens boards
store the bootcount in the environment, as we have no softreset
save registers on this hardware. Use therefore the CONFIG_BOOTCOUNT_ENV
bootcount driver.
- change spi mode from 3 to 0 for the lcd init
- add gpio pin for lcd reset with state 0 and add mdelay
- siemens boards: use own USB id's
- add dfu serial and device number for siemens boards
Add for the siemens boards the possibility to define in dfu mode,
the iSerialNumber and the bcdDevice fields in the USB Device
descriptor.
- fix upgrade mechanism based on bootcount
Correct location of saveenv and remove not active variable.
Add CONFIG_BOOT_RETRY_TIME and CONFIG_RESET_TO_RETRY to
reboot board in case of empty kernel partition. Without
these defines an empty kernel partition leads to an
abort of boot process and one remains in u-boot prompt.
- general cleanup of dxr2, pxm2 and rut boards
all:
* Remove net boot from bootcmd
Ping can cause a crash on boards without ethernet phy.
net_nfs command is used only for development
* Add reset at the end of bootcmd
In order to have an immediate reset of the boot when bootcmd
fails, add reset at the end of bootcmd.
rut:
* add nand_img_size
dxr2:
* update nand_img_size
* ddr3 timings updated with iocontrol property that can be
modified via eeprom. New default parameters from software
leveling with draco ES2.
Signed-off-by: Pascal Bach <pascal.bach@siemens.com>
Signed-off-by: Roger Meier <r.meier@siemens.com>
Cc: Matthias Michel <matthias.michel@siemens.com>
Cc: Tom Rini <trini@ti.com>
add support for the am335x based boards from siemens:
dxr2:
- DDR3 128MiB
- NAND 256MiB
- Ethernet with external Switch SMSC LAN9303
- no PMIC
- internal Watchdog
- DFU support
pxm2:
- DDR2 512 MiB
- NAND 1024 MiB
- PMIC
- PHY atheros ar803x
- USB Host
- internal Watchdog
- DFU support
rut:
- DDR3 256 MiB
- NAND 256 MiB
- PMIC
- PHY natsemi dp83630
- external Watchdog
- DFU support
