path: root/include/configs/puma_rk3399.h
2017-06-07rockchip: board: puma_rk3399: enable BMP_16BPP, BMP_24BPP and BMP_32BPPPhilipp Tomsich
With video output support for the RK3399-Q7 (Puma) available, we want CMD_BMP enabled and the support for 16bit, 24bit and 32bit BMPs defined. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Version-changes: 2 - enable SYS_WHITE_ON_BLACK via defconfig Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: board: puma_rk3399: add support for serial# and cpuid# via efusesPhilipp Tomsich
With our efuse driver for the RK3399 ready, we can add the board-specific code that consumes the cpuid from the efuse block and postprocesses it into the system serial (using the same CRC32 based derivation as in Linux). We expose the cpuid via two distinct environment variables: serial# - the serial number, as derived in Linux cpuid# - the raw 16 byte CPU id field from the fuse block Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-15rockchip: ARM64: split RK3399-Q7 board off the RK3399-EVB boardKlaus Goger
The RK3399-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 connector) system-on-module from Theobroma Systems, featuring the Rockchip RK3399. It provides the following feature set: * up to 4GB DDR3 * on-module SPI-NOR flash * on-module eMMC (with 8-bit interace) * SD card (on a baseboad) via edge connector * Gigabit Ethernet w/ on-module Micrel KSZ9031 GbE PHY * HDMI/eDP/MIPI displays * 2x MIPI-CSI * USB - 1x USB 3.0 dual-role (direct connection) - 2x USB 3.0 host + 1x USB 2.0 (on-module USB 3.0 hub) * on-module STM32 Cortex-M0 companion controller, implementing: - low-power RTC functionality (ISL1208 emulation) - fan controller (AMC6821 emulation) - USB<->CAN bridge controller Note that we use a multi-payload FIT image for booting and have Cortex-M0 payload in a separate subimage: we thus rely on the FIT image loader to put it into the SRAM region that ATF expects it in. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Fixed build warning on puma-rk3399: Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
