path: root/include/configs/pm9g45.h
2010-12-16pm9g45: enable cache commandAsen Dimov
Signed-off-by: Asen Dimov <dimov@ronetix.at>
2010-12-16pm9g45: ARM relocation supportAsen Dimov
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-06-06add new board pm9g45Asen Dimov
Add the new board PM9G45 from Ronetix GmbH. * AT91SAM9G45 MCU at 400Mhz. * 128MB DDR2 SDRAM * 256MB NAND * 10/100 MBits Ethernet DP83848 * Serial number chip DS2401 The board is made as SODIMM200 module. For more info www.ronatix.at or info@ronetix.at. Signed-off-by: Asen Dimov <dimov@ronetix.at>
