Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Now that include/config_fallbacks.h define a sane fallback for
CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all
configurations that were using the default value.
[trini: Drop <config.h> from stih410-b2260.h]
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
Add the dts files to support deivce tree, update the configuration
files to support the device tree and driver model. The peripheral
clock and pins configuration are handled by the clock and the pinctrl
drivers respectively.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
Tested-by: Adam Ford <aford173@gmail.com>
CONFIG_ENV_IS_IN_DATAFLASH
CONFIG_ENV_IS_IN_FLASH
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_SYS_WHITE_ON_BLACK
[trini: Make this default y on various SoCs]
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
With the latest mach-types values we have many instances where we no
longer need to define a value and a few cases where the name (but not
value) have changed slightly.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_LCD
Reviewed-by: Jagan Teki <jteki@openedev.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
Signed-off-by: Georgi Botev <botev@ronetix.at>
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h
and define a default value. Delete this define in the board
config files, where it is possible (all boards use currently
the same value).
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de>
Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de>
Acked-by: Scott Wood <scottwood@freescale.com>
The PLLADIV2 bit is not defined in at91sam9261 SoC, so remove it.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
board/compulab/cm_t35/Makefile
board/corscience/tricorder/Makefile
board/ppcag/bg0900/Makefile
drivers/bootcount/Makefile
include/configs/omap4_common.h
include/configs/pdnb3.h
Makefile conflicts are due to additions/removals of
object files on the ARM branch vs KBuild introduction
on the main branch. Resolution consists in adjusting
the list of object files in the main branch version.
This also applies to two files which are not listed
as conflicting but had to be modified:
board/compulab/common/Makefile
board/udoo/Makefile
include/configs/omap4_common.h conflicts are due to
the OMAP4 conversion to ti_armv7_common.h on the ARM
side, and CONFIG_SYS_HZ removal on the main side.
Resolution is to convert as this icludes removal of
CONFIG_SYS_HZ.
include/configs/pdnb3.h is due to a removal on ARM side.
Trivial resolution is to remove the file.
Note: 'git show' will also list two files just because
they are new:
include/configs/am335x_igep0033.h
include/configs/omap3_igep00x0.h
Get rid of too many ifdeffery in usb ohci driver
Add following two configuration for USB clock selecting
- CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock
- CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
[trini: Fixup common/cmd_io.c]
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
This change follows the change by Wolfgang Grandegger (commit 6c869637fef),
which allows to remove useless NAND_MAX_CHIPS definitions in board config
files.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Scott Wood <scottwood@freescale.com>
The early messages can be seen on the debug console.
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at>
Change my old email address which is no longer valid.
Signed-off-by: Stelian Pop <stelian@popies.net>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Signed-off-by: Asen Dimov <dimov@ronetix.at>
For ARM systems, before ELF relocation was introduced,
CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the
U-Boot image from whereever it was loaded to it's link address
(CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation
was performed at all, it was just a memcpy().
With ELF relocation, this does not work like that any more, and
related boards need to be fixed anyway. So don't keep this relict any
longer.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Configuration defines should be preceeded with CONFIG_SYS_. Renamed
some at91 specific defines to conform to this naming convention:
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME
AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
* add a real AT91 GPIO driver instead of header inline code
* resolve the mixing of port and pins
* change board config files to use new driver
* add macros to gpio to realize backward compatibility
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
* add's the new temporary CONFIG_AT91_LEGACY to all board configs
This will need for backward compatiblity, while change the SoC access
to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated
SoC is used.
