path: root/include/configs/plutux.h
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2013-04-15Tegra: Plutux: Enable NAND and boot script supportThierry Reding
Boot script support brings Plutux in line with other Tegra boards. In order to enable booting a Linux kernel with initial ramdisk, also add support for the new FIT image type. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14ARM: tegra: enable a common set of disk-related commands everywhereStephen Warren
Enable a common set of partition types, filesystems, and related commands in tegra-common.h, so that they are available on all Tegra boards. This allows boot.scr (loaded and executed by the default built-in environment) on those boards to assume that certain features are always available. Do this in tegra-common.h, so that individual board files can undefine the features if they really don't want any of them. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: plutux: Add device tree supportThierry Reding
Device tree support is required for working USB host support, which in turn enables ethernet support. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07arm: Tegra: Use ODMDATA from BCT in IRAMTom Warren
Walk the BIT and BCT to find the ODMDATA word in the CustomerData field and put it into Scratch20 reg for use by kernel, etc. Built all Tegra builds OK; Booted on Seaboard and saw ODMDATA in PMC scratch20 was the same as the value in my burn-u-boot.sh file (0x300D8011). NOTE: All flash utilities will have to specify the odmdata (nvflash --odmdata n) on the command line or via a cfg file, or built in to their BCT. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2012-07-07mmc: tegra2: rename tegra2_mmc.* to tegra_mmc.*Tom Warren
In anticipation of Tegra3 support, continue removing/renaming Tegra2-specific files. No functional changes (yet). Updated copyrights to 2012. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: flesh out bootcmdStephen Warren
This implements a useful bootcmd for Tegra. The boot order is: * If USB enabled, USB storage * Internal MMC (SD card or eMMC) * If networking is enabled, BOOTP/TFTP When booting from USB or MMC, the boot script is assumed to be in partition 1 (although this may be overridden via the rootpart variable), both ext2 and FAT filesystems are supported, the boot script may exist in either / or /boot, and the boot script may be named boot.scr.uimg or boot.scr. When booting over the network, it is assumed that boot.scr.uimg exists on the TFTP server. There is less flexibility here since those setting up network booting are expected to need less hand-holding. In all cases, it is expected that the initial file loaded is a U-Boot image containing a script that will load the kernel, load any required initrd, load any required DTB, and finally bootm the kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: remove some cruft from CONFIG_EXTRA_ENV_SETTINGSStephen Warren
console isn't used by anything, and the kernel should be set appropriately by whatever script is booting the kernel, not imposed by the bootloader. mem might be useful, but the current value is pretty bogus, since it includes nvmem options that make no sense for an upstream kernel, and equally should not be required for any downstream kernel. Either way, this is also best left to the kernel boot script. smpflag isn't used by anything, and again was probably intended to be a kernel command-line option better set by the kernel boot script. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra: Fix build error in plutux, medcomSimon Glass
We need to define CONFIG_ENV_IS_NOWHERE to avoid this error: cmd_nvedit.c:69:3: error: #error Define one of CONFIG_ENV_IS_IN_... Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Plutux support.Thierry Reding
The Plutux is a set-top box device based on the Tamonten processor module. It can be connected to a display via an HDMI output. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
