path: root/include/configs/platinum_titanium.h
2018-04-08treewide: Convert CONFIG_HOSTNAME to a string optionMario Six
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every use is couched by __stringify(...). Hence, convert it to a proper string option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-03-09ARM: Drop unreferenced CONFIG_* defines named after boardsTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AT91SAM9263EK CONFIG_AT91SAM9RLEK CONFIG_BARIX_IPAM390 CONFIG_BOARD_H2200 CONFIG_EP9301 CONFIG_KZM_A9_GT CONFIG_PICOSAM CONFIG_PLATINUM_PICON CONFIG_PLATINUM_TITANIUM CONFIG_PM9261 CONFIG_PM9263 CONFIG_PM9G45 CONFIG_SIEMENS_DRACO CONFIG_SIEMENS_PXM2 CONFIG_SIEMENS_RUT CONFIG_SMDKC100 CONFIG_SMDKV310 CONFIG_STM32F4DISCOVERY Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-07configs: Replace deprecated Micrel defines with PHY_MICREL_KSZ90X1Alexandru Gagniuc
These boards will now use the ksz90x1 driver instead of the mess in ksz8xxx. This change is needed before the two drivers can be fully separated. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-01-19arm: mx6: Add Barco platinum-picon and platinum-titaniumStefan Roese
This patch adds the new Barco platinum platform. It currently includes those two boards: platinum-titanium ----------------- This is the same board as the titanium that is already supported in mainline U-Boot. But its now moved to this new platform to support multiple "flavors" of imx6 boards in one directory. Its also moved to support SPL booting. And with this we use the run-time DDR configuration of this SPL support. The board is equipped with the Micron MT41J128M16JT-125 DDR chips. We now can remove the DDR related registers tuples from the imximage.cfg file. As all this is done in the SPL at run-time. platinum-picon -------------- This board is new and based on the MX6DL with 1GiB DDR using the Micron MT41K256M16HA DDR3 chips. Its also equipped with 2 NAND chips (each 512MiB). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Pieter Ronsijn <pieter.ronsijn@barco.com>
