path: root/include/configs/picosam9g45.h
2018-11-16arm: at91: wdt: Convert watchdog driver to dm/dtPrasanthi Chellakumar
Convert the Watchdog driver for AT91SAM9x processors to support the driver model and device tree. Changes "CONFIG_AT91SAM9_WATCHDOG" to new "CONFIG_WDT_AT91" Kconfig option. Signed-off-by: Prasanthi Chellakumar <prasanthi.chellakumar@microchip.com>
2018-03-09ARM: Drop unreferenced CONFIG_* defines named after boardsTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AT91SAM9263EK CONFIG_AT91SAM9RLEK CONFIG_BARIX_IPAM390 CONFIG_BOARD_H2200 CONFIG_EP9301 CONFIG_KZM_A9_GT CONFIG_PICOSAM CONFIG_PLATINUM_PICON CONFIG_PLATINUM_TITANIUM CONFIG_PM9261 CONFIG_PM9263 CONFIG_PM9G45 CONFIG_SIEMENS_DRACO CONFIG_SIEMENS_PXM2 CONFIG_SIEMENS_RUT CONFIG_SMDKC100 CONFIG_SMDKV310 CONFIG_STM32F4DISCOVERY Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-28configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate existing USB_EHCI_xxx optionsTom Rini
The following options are migrated over fully now: - USB_EHCI_ATMEL - USB_EHCI_MARVELL - USB_EHCI_MX6 - USB_EHCI_MX7 - USB_EHCI_MSM - USB_EHCI_ZYNQ - USB_EHCI_GENERIC This also requires fixing the depends on USB_EHCI_MARVELL as it's used by Orion5X and Kirkwood as well. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2015-08-28picosam9g45: adopt CONFIG_SYS_PROMPTAndreas Bießmann
Commit 181bd9dc61d2da88b78f1c1138a685dae39354d6 introduced Kconfig selection for SYS_PROMPT. When applying the new picosam9g45 board this change slipped through, adopt it. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: add support for mini-box picosam9g45 boardErik van Luijk
Bootlog: U-Boot SPL 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21) mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 33024000 Hz, block size 512 reading u-boot.img reading u-boot.img U-Boot 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21 +0000) CPU: AT91SAM9G45 Crystal frequency: 12 MHz CPU clock : 400 MHz Master clock : 133.333 MHz Watchdog enabled DRAM: 256 MiB WARNING: Caches not enabled MMC: mci: 0 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 33333333 Hz, block size 512 reading uboot.env In: serial Out: serial Err: serial Net: macb0 Error: macb0 address not set. Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [add 'picosam9g45_defconfig' to MAINTAINERS] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
