path: root/include/configs/pico-imx6ul.h
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-07-28pico-imx6ul: drop warning due to redefinedStefano Babic
USB gadget configuration is set in defconfig and must be removed from pico-imx6ul.h. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-19pico-imx6ul: Add PMIC supportVanessa Maegima
Add PMIC support. Tested by command "pmic PFUZE3000 dump". Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12pico-imx6ul: Add USB Host supportVanessa Maegima
Add USB host support. Tested by connecting a USB pen drive: => usb start starting USB... USB0: Port not available. USB1: USB EHCI 1.00 scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12pico-imx6ul: Add NFS boot supportDiego Dorta
Add script for retrieving the kernel via TFTP and mounting the rootfs via NFS. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12pico-imx6ul: Add DFU supportVanessa Maegima
DFU is a convenient way to program U-boot binary into the eMMC. Add support for it. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12pico-imx6ul: Add Ethernet supportDiego Dorta
Pico-imx6ul has a KSZ8081 Ethernet PHY. Add support for it. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-04-25pico-imx6ul: Update the defconfigTom Rini
The defconfig/config.h file were merged but were already out of sync with mainline. This brings them further into line now. Cc: Richard Hu <richard.hu@technexion.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-19Add initial support for Technexion's PICO-IMX6UL-EMMC boardFabio Estevam
Add support for Technexion's PICO-IMX6UL-EMMC board. For information about this board, please visit: http://www.technexion.com/products/pico/pico-som/pico-imx6-emmc Signed-off-by: Richard Hu <richard.hu@technexion.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
