path: root/include/configs/pic32mzdask.h
2016-05-31MIPS: Split I & D cache line size configPaul Burton
Allow L1 Icache & L1 Dcache line size to be specified separately, since there's no architectural mandate that they be the same. The [id]cache_line_size functions are tidied up to take advantage of the fact that the Kconfig entries are always present to simply check them for zero rather than needing to #ifdef on their presence. Signed-off-by: Paul Burton <paul.burton@imgtec.com> [removed CONFIG_SYS_CACHELINE_SIZE in include/configs/pic32mzdask.h] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-10board: pic32mzda: enable USB-host, USB-storage support.Purna Chandra Mandal
Enable MUSB host and USB storage support for Microchip PIC32MZ[DA] Starter Kit. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
2016-02-01board: Enable ethernet, tftpboot support to pic32mzdask board.Purna Chandra Mandal
This adds ethernet, TFTP support for PIC32MZ[DA] Starter Kit. Also custom environment variables/scripts are added to help boot from network. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
2016-02-01board: add SDHCI support for PIC32MZDASK board.Purna Chandra Mandal
Enable MMC, SDHCI, FAT_FS support for PIC32MZ[DA] StarterKit. Also add custom scripts, rules to boot Linux from microSD card. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
2016-02-01board: Add Microchip PIC32MZ[DA]-Starter-Kit board.Purna Chandra Mandal
This adds support for Microchip PIC32MZ[DA] StarterKit board based on a PIC32MZ[DA] family of microcontroller. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
