The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
We do not support a processor that never reached a real customer.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Added new CONFIG options for the three type of MAC-PHY interconnect and
applied them all relevant board config files
- #if CFG_ENV_IS_IN_FLASH
- #if (CFG_ENV_IS_IN_FLASH == 1)
- #define CFG_ENV_IS_IN_FLASH 0
Change all code that conditionally operates on high bat
registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS
instead of the myriad ways this is done now. Define the option
for every config for which high bats are supported (and
enabled by early boot, on parts where they're not always
enabled)
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define
CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining
them does not cause PCI or IPB clocks to run at the specified speed.
Instead, they configure divisors used to calculate said clocks. This
patch renames the defines according to their real function.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
Patch by Reinhard Arlt, 22 Aug 2005
