These boards are still non-generic boards.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
We do not have to define CONFIG_MPC5xxx in board config headers
(and start.S) because it is defined in arch/powerpc/cpu/mpc5xxx/config.mk.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
[trini: Fixup common/cmd_io.c]
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
We do not support a processor that never reached a real customer.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Added new CONFIG options for the three type of MAC-PHY interconnect and
applied them all relevant board config files
- #if CFG_ENV_IS_IN_FLASH
- #if (CFG_ENV_IS_IN_FLASH == 1)
- #define CFG_ENV_IS_IN_FLASH 0
Change all code that conditionally operates on high bat
registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS
instead of the myriad ways this is done now. Define the option
for every config for which high bats are supported (and
enabled by early boot, on parts where they're not always
enabled)
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define
CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining
them does not cause PCI or IPB clocks to run at the specified speed.
Instead, they configure divisors used to calculate said clocks. This
patch renames the defines according to their real function.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
Patch by Reinhard Arlt, 22 Aug 2005
