path: root/include/configs/pepper.h
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-07configs: Replace deprecated Micrel defines with PHY_MICREL_KSZ90X1Alexandru Gagniuc
These boards will now use the ksz90x1 driver instead of the mess in ksz8xxx. This change is needed before the two drivers can be fully separated. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-05-11configs: am335x_evm: Use omap2 generic spl load scriptLokesh Vutla
No reason to use a separate load script for am33xx than using omap-common load script. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-07-27Update the rootfs type to ext4 for Overo and PepperAdam YH Lee
Gumstix is migrating from ext3 to ext4 file system. Signed-off-by: Adam YH Lee <adam.yh.lee@gmail.com> Acked-by: Ash Charles <ashcharles@gmail.com>
2015-06-08pepper: Implement Board Detection mechanismAdam YH Lee
AM335x-based 'Gumstix Pepper' SBCs and variants use different types of RAM (DDR2 vs DDR3 with DDR3 being the default). Detect the board type by reading the factory-programmed EEPROM [1] and use this to select any runtime boot options such as RAM type. [1] http://elinux.org/BeagleBoardPinMux#List_of_Vendor_and_Device_IDs Signed-off-by: Adam YH Lee <adam.yh.lee@gmail.com> Signed-off-by: Ash Charles <ashcharles@gmail.com>
2014-05-13am335x: pepper: Add Gumstix Pepper AM335x-based machineAsh Charles
This adds the Gumstix Pepper[1] single-board computer based on the TI AM335x processor. Schematics are available [2]. [1] https://store.gumstix.com/index.php/products/344/ [2] https://pubs.gumstix.com/boards/PEPPER/ Signed-off-by: Ash Charles <ash@gumstix.com> [trini: Move 'cdev' in board.c down to under #ifdef's where it's used] Signed-off-by: Tom Rini <trini@ti.com>
