path: root/include/configs/peach-pi.h
2015-08-05video: Remove the old parade driverSimon Glass
We have a new one which uses driver model and device tree configuration. Remove the old one. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-04-06config: peach: Correct memory layout environment settingsSjoerd Simons
The peach boards have their SDRAM start address at 0x20000000 instead of 0x40000000 which seems common for all other exynos5 based boards. This means the layout set in exynos5-common.h causes the kernel be loaded more then 128MB (at 0x42000000) away from memory start which breaks booting kernels with CONFIG_AUTO_ZRELADDR Define a custom MEM_LAYOUT_ENV_SETTINGS for both peach boards which uses the same offsets from start of memory as the common exynos5 settings. This fixes booting via bootz and PXE Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-19dm: cros_ec: Convert to KconfigSimon Glass
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses. LPC will need to wait until driver mode PCI is available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: exynos: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-22config: exynos5420: move non common configs to specific board filesHyungwon Hwang
The media for boot and environment is a board-specific feature, not a processor-specific. This is same to console port number and some other addresses. This patch moves the that kinds of configs to each board-specific files from the common config file for Exynos5420. Signed-off-by: Hyungwon Hwang <human.hwang@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17Config: Exynos5420: Refactor SDRAM Bank and SizeAkshay Saraswat
Since, not every board may have all memory channels configured and all available banks of DMC used, we wish to refactor configs for Memory Bank size and numbers as per board memory config. For Example, Peach-Pit has 2GB memory and will be using only 4 banks but Peach-Pi has 3.5GB memory and will be using all 7 available SDRAM banks. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17Config: Exynos5800: Enable build for Peach-PiAkshay Saraswat
This adds following things : - New config and defconfig for Peach-Pi board. - Alterations in Kconfig and MAINTAINERS. - Addition of CONFIG_EXYNOS5800. - ADdition of exynos5800-peach-pi in dts list. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
