path: root/include/configs/pdm360ng.h
2014-10-27powerpc: pdm360ng: convert to generic boardAnatolij Gustschin
2014-01-24powerpc: mpc512x: remove redundant CONFIG_MPC512X definitionMasahiro Yamada
We do not have to define CONFIG_MPC512X in board config headers because it is defined in arch/powerpc/cpu/mpc512x/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-28mpc: iim: Switch to common fsl_iimBenoît Thébaudeau
Make all mpc512x code point to the new common fsl_iim driver, and remove the former mpc512x-specific iim driver. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-09mpc512x: use common code for clock setting for all mpc512x boardsAnatolij Gustschin
Only define enabled clocks in the config file and enable the clocks in common code. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Wolfgang Denk <wd@denx.de>
2013-03-09mpc512x: use common code for CSx configurationAnatolij Gustschin
Remove CSx configurations from board code and only define required CSx macros in the board config file to configure chip select windows and parameters. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Wolfgang Denk <wd@denx.de>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-04-28powerpc: use 'video-mode' environment variable to configure DIUTimur Tabi
Use the 'video-mode' environment variable (for Freescale chips that have a DIU display controller) to designate the full video configuration. Previously, the DIU driver used the 'monitor' variable, and it was used only to determine the output video port. The old definition of the "monitor" environment variable only determines which video port to use for output. This variable was set to a number (0, 1, or sometimes 2) to specify a DVI, LVDS, or Dual-LVDS port. The resolution was hard-coded into board-specific code. The Linux command-line arguments needed to be hard-coded to the proper video definition string. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-09-23e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernelsIra W. Snyder
Newer Linux kernels can overrun the initial memory window used for booting with their BSS area. When this happens, they overwrite the FDT and silently fail to boot. On e300 CPUs, the Linux kernel uses an initial BAT covering the first 256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value allowed by Linux. This will allow very large kernels to boot. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-04-24mpc5121: pdm360ng: add coprocessor POSTAnatolij Gustschin
Adds coprocessor communication POST code Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-24mpc5121: add support for PDM360NG boardAnatolij Gustschin
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh. Signed-off-by: Michael Weiss <michael.weiss@ifm.com> Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
