path: root/include/configs/palmld.h
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-21lcd, pxafb: move the pxafb to drivers/videoJeroen Hofstee
Since the lcd code was compiled unconditionally for pxa also add CONFIG_PXA_LCD to the boards using this framebuffer. Since driver/video contains video and lcd drivers, add lcd to the name to make clear it belongs to common/lcd.c. cc: Anatolij Gustschin <agust@denx.de> cc: Cliff Brake <cliff.brake@gmail.com> cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2012-11-19pxa: Disable dcache on palmld, palmtc, zipitz2Simon Glass
These platforms don't include dcache support. Define CONFIG_SYS_DCACHE_OFF so that functions don't try to call non-existent routines like flush_dcache_range(). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15serial: pxa: Make use of default_serial_console in serial_pxaMarek Vasut
Make use of the newly implemented weak default_serial_console in the serial_pxa driver. This removes all reimplementations of this function from board files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]XMarek Vasut
2010-10-22PXA: palmld: Fix for relocMarek Vasut
2010-10-19PXA: Add necessary information for RELOCMarek Vasut
2010-10-19PXA: Add initial Palm LifeDrive supportMarek Vasut
