path: root/include/configs/p3p440.h
2015-09-02powerpc: ppc4xx: remove p3p440 supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various p* named board config files.Jon Loeliger
2007-06-25Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-04-06Merge with /home/sr/git/u-boot/cfi-flashWolfgang Denk
2006-04-01* Changes/fixes for drivers/cfi_flash.c:Stefan Roese
- Add Intel legacy lock/unlock support to common CFI driver On some Intel flash's (e.g. Intel J3) legacy unlocking is supported, meaning that unlocking of one sector will unlock all sectors of this bank. Using this feature, unlocking of all sectors upon startup (via env var "unlock=yes") will get much faster. - Fixed problem with multiple reads of envronment variable "unlock" as pointed out by Reinhard Arlt & Anders Larsen. - Removed unwanted linefeeds from "protect" command when CFG_FLASH_PROTECTION is enabled. - Changed p3p400 board to use CFG_FLASH_PROTECTION Patch by Stefan Roese, 01 Apr 2006 * Changes/fixes for drivers/cfi_flash.c: - Correctly handle the cases where CFG_HZ != 1000 (several XScale-based boards) - Fix the timeout calculation of buffered writes (off by a factor of 1000) Patch by Anders Larsen, 31 Mar 2006
2006-03-31Updates to common PPC4xx onboard (DDR)SDRAM init code (405 and 440)Stefan Roese
405 SDRAM: - The SDRAM parameters can now be defined in the board config file and the 405 SDRAM controller values will be calculated upon bootup (see PPChameleonEVB). When those settings are not defined in the board config file, the register setup will be as it is now, so this implementation should not break any current design using this code. Thanks to Andrea Marson from DAVE for this patch. 440 DDR: - Added function sdram_tr1_set to auto calculate the TR1 value for the DDR. - Added ECC support (see p3p440). Patch by Stefan Roese, 17 Mar 2006
2005-11-22Add support for Prodrive P3P440 board:Stefan Roese
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005
